Fs 2000 bmw m5
Fs 2000 bmw m5
Year: 2000
Make: BMW
Model: M5
Price: $19400
Mileage: 126387
Color: Carbon Black Metallic
Location (State): NY
Transmission: Manual
Drivetrain: Rear Wheel Drive
I purchased the car in July of 2008 in Florida, it was previously out west. Here is ALL the information on the car, as well as photos. There are a few small scratches on the front bumper as highlighted in photos, and one blemish on the rear bumper as well. The car has absolutely ZERO dents or dings in it. All gauges work, absolutely no dead pixels in the dash cluster.
2000 BMW M5
Carbon Black Metallic (Paint Code 416)
Trim Code M1SW - Black Leather
Production Date 09/1999
Retail Date 11/19/1999
Original Point of Sale: New Century BMW - Alhambra, CA
Warranty Expiration 11/19/2003
CPO enrollment 10/29/2002
Current Mileage: 126,387
Original Option Codes:
0320 - Badge Delete (has been added back at some point since then)
0438 - Wood Trim - Updated to silver with silver vinyl, the lighted shift ****, ash tray, and parking brake handle will need to have silver parts purchased from BMW as they were too difficult to wrap with vinyl.
0465 - Fold down rear seats with ski pass through
0508 - Rear park distance control
0769 - 100% options (covers extended leather, luxury seats vs sport, etc)
0971 - M5 Floor Mats
Maintenance:
(There was other service done to the vehicle, however this is what I have EXACT records for)
Date : Miles : Service
12/99 1,233 Oil Service
3/2001 14,596 BMW Service 2 / MAF replacement / Oil service Loose fog light
6/2002 35,879 Valve Cover Gasket / Radiator Cap / Front pads and rotors / washer res sprayer / tires / 02 sensor / oil service
6/2003 44,455 02 sensor / oil service
7/2003 46,564 Blower HVAC output
12/2003 52,152 Camshaft sensor
3/2005 67,361 Power steering return line
6/2005 69,218 ECU Update
8/2005 70,185 Air shutoff valve
9/2005 71,665 Secondary Air Line
Then the records are blank until I purchased it,
9/2008 93,822 New shocks, brake pads, rotors, rear mufflers removed (kept cats and resonators, still legal just sounds fantastic), new plugs, tires
10/2008 95,012 New clutch, cam shaft sensor, 02 sensors, new pass rear and driver's front window regulators, depo headlights with 6k HID lows, french'd highs, 6k HID fogs, Cold air intakes, new mafs oil service
10/2008 100,869 oil service, tires
12/2008 118,349 New zionsville aluminum radiator, expansion tank, high flow electric fan and aluminum shroud, new radiator hoses, new air oil seperator valves and hoses. Valve cover gaskets, coil pack cover gaskets, lower oil pan gasket, 02 sensor, intake manifold removed, throttle bodies cleaned, new plenum gasket
3/2009 123,102 Power steering pump, oil service, diff service, trans service, shifter bushings
4/2009 123,760 Steering center link, tie rods, car realigned
7/2009 125,880 Fuel Pump, in tank fuel lines, front pads, front brake calipers, front rotors turned, wheel bearing replaced
Modifications:
Mufflers removed, cats and resonators still in place
Cold Air Intakes
Powerchip (Tweaks throttle response, bumpers power up a hair, removes speed limiter, and options "Sport" mode on, at startup)
Hawk Pads
Widescreen 2001+ Navigation Screen
Euro Brake Ducts
Euro Front Fender Liners
ASA AR-1 Wheels (18x9.5" all four)
M Parallel Replica wheels (no tires, staggered, 18x8.5" 18x10.5")
Silver vinyl trim
Photos:
ASKING $19,400 USD or best offer
Slightly cheaper to run hard at events. I'd feel bad going body contact with another car in such a clean M5.
