2007 Porsche 997 Turbo VR825 kit and RED HRE
Old Aug 3, 2012 | 08:53 AM
mcjoe691's Avatar
mcjoe691 has much to be proud ofmcjoe691 has much to be proud ofmcjoe691 has much to be proud ofmcjoe691 has much to be proud ofmcjoe691 has much to be proud ofmcjoe691 has much to be proud ofmcjoe691 has much to be proud ofmcjoe691 has much to be proud ofmcjoe691 has much to be proud ofmcjoe691 has much to be proud of
Year: 2007
Make: Porsche
Model: 911
Price: $85000
Mileage: 23600
Color: Slate Gray
Location (State): FL
Transmission: Manual
Drivetrain: 4WD & AWD
Price dropped to 85K was trading in for a 2013 GTS Cayane and dealer wanted to give me 80k for my car . I think my car is worth 85k or more ! I will take 85k if interested . Call me 201-658-2004 cell JOE
Everyone knows this car dont have to say too much about it.....
Proven Numbers:
  • Race Mode the car makes 760awhp at 1.6bar of boost on our Mustang Dyno
  • Low Boost Street Mode the car makes 600awhp at 1.2bar of boost on our Mustang Dyno
  • Verified 60-130mph Best Time is 6.04 secs.
  • Verified TX Mile Top Speed Fastests Stock Motor 997 Turbo is 206.2mph
  • Best 1/4mile Trap Speed is 135mph
  • Best 0-60mph time of 3.04sec.
Modification List:
Engine/Performance:
  • Vivid Racing 825HP Performance Kit
    • Custom Aluminum 3inch Y-Pipe Painted Slate Gray with Red Couplers. Features water injection bungs.
    • Custom Throttlebody Plenum Pipe with larger 78mm Cayenne TT ThrottleBody
    • Converted Porsche oil and water fittings to AN for Garrett turbos
    • Garrett GT3076rs Turbochargers with a .63a/r
    • Tial 44mm External Wastegates with .8bar spring.
    • Agency Power High Flow Bar and Plate Intercoolers Modified with 3inch outlets to 3inch YPipe
    • Agency Power Lower Silicone Boost Hoses Red
    • Agency Power Fender Mount Cold Air Intakes Retaining OEM MAF Sensors and BOV Recirc Tubes
    • Agency Power Twin Adjustable Blow Off Valves set up 50/50
    • Agency Power High Flow Performance Headers for Garrett turbos and Tial Wastegates
    • JIC Cross 80mm Exhaust System with 100 cell Cats
    • Softronic custom ECU Tuning. VTG delete mod, race gas and pump gas map.
    • Greddy Profec B Electronic Boost Controller
    • AEM Water/Meth Injection Kit
    • Nitrous Express Dual Intercooler Spray Kit
Exterior:
  • Vorsteiner VRT Carbon Fiber Front Bumper
  • Vorsteiner VRT Carbon Fiber Rear Bumper
  • Vorsteiner VRT Carbon Fiber Rear Wing
  • NR Auto Carbon Mirror Inserts
  • [COLOR=black]TechArt Side Skirts[/COLOR
  • Porsche OEM Clear Side Markers
  • Front End has 3M clear bra under wrap
Suspension:
  • KW V3 Adjustable Coilovers
  • Agency Power Front Adjustable 27mm Sway Bar
  • Agency Power Rear Adjustable 24mm Sway Bar
  • Agency Power Front Adjustable Sway Bar Links
  • Agency Power Rear Adjustable Control Arms
  • Corner Balanced and Aligned - GT2 Specs
Wheels/Tires:
  • HRE C93 Competition Racing Wheels 19x8.5 and 19x11 Flat Black Center/Gloss Black Lip. Front weight of 19lbs rear of 20.5lbs. These wheels will go with the car if you buy at 90K
  • HRE P40SC Brush Red Nitto Tires 20x13 Rear and 20x19 front ( 345 /245 )
Brakes:
  • Brembo 2pc Floating Slotted Rotors Front - 4lbs lighter then stock
  • Brembo 2pc Floating Slotted Rotors Rear - 3lbs lighter then stock
  • Endless Racing Brake Fluid
Transmission:
  • Agency Power Short Throw Shifter Kit
  • Agency Power Precision Shift Linkage
  • Clutch Masters Stage 3 Full Disk Clutch Kit
Interior:
  • Agency Power Bolt-in Performance Roll Bar with harness and diagonal bar painted Red color of the stock HRE C93
  • Red Seat Belts
  • Carbon Trim Shift ****, Brake Lever, Cup Holder Trim
  • Slate Gray Center Console
  • Laser Jammers by Blinder
  • Custom switches for NX and AEM Kit in Ash Tray
  • DCT Custom Flat Bottom Steering Wheel with carbon fiber, preforated leather, and suede
  • Renline Pedals
  • Alcantera shifter and center arm rest cover.
New Techart LED lights costume done to fit VRT Bumper!
Just had oil changed . Car is hardly used since i moved to FLORIDA….
I can be reached on my cell 201-658-2004 or via email mcjoe691@aol.com had someone comment on the front fenders they are wrapped in clear film with the hood also.
ID:	316734   Click image for larger version
ID:	316794   Click image for larger version
ID:	316795   Click image for larger version
Old Aug 3, 2012 | 11:01 AM
VID997's Avatar
VID997 Is a GOD !VID997 Is a GOD !VID997 Is a GOD !VID997 Is a GOD !VID997 Is a GOD !VID997 Is a GOD !VID997 Is a GOD !VID997 Is a GOD !VID997 Is a GOD !VID997 Is a GOD !VID997 Is a GOD !
WOW! That was quick....????....
Old Aug 3, 2012 | 11:28 AM
unvmy996's Avatar
yeah no kidding .... you just got this thing, why are you selling it allready ?
Old Aug 3, 2012 | 12:35 PM
mcjoe691's Avatar
I am looking into buying some houses in Florida with my old man to flip. Need some cash on hand!!! didnt want to do this but this will bring in more money to buy something more CRAZY!!! I will miss her greatly !!! she is a GEM
Old Aug 3, 2012 | 01:20 PM
r_matt_6's Avatar
r_matt_6 has much to be proud ofr_matt_6 has much to be proud ofr_matt_6 has much to be proud ofr_matt_6 has much to be proud ofr_matt_6 has much to be proud ofr_matt_6 has much to be proud ofr_matt_6 has much to be proud ofr_matt_6 has much to be proud ofr_matt_6 has much to be proud ofr_matt_6 has much to be proud of
I've been thinking about unloading my car to do the same thing. Was just in FL last week to check out houses and you can grab something decent REEAAL CHEAP!
bump and GLWS!
Old Aug 3, 2012 | 11:58 PM
Turbroe's Avatar
Turbroe is a jewel in the roughTurbroe is a jewel in the roughTurbroe is a jewel in the rough
Great car, Great guy, good history... GLWS Joe. I was hoping to see this one
Old Aug 4, 2012 | 01:25 PM
mcjoe691's Avatar
Thanks Turbroe not letting it go easy ! I might still have it.....
Old Aug 4, 2012 | 01:27 PM
mcjoe691's Avatar
bump and GLWS!
Thanks r_matt-6 yeah on the way there to check something out !
Old Aug 4, 2012 | 01:54 PM
dsu*'s Avatar
dsu* has much to be proud ofdsu* has much to be proud ofdsu* has much to be proud ofdsu* has much to be proud ofdsu* has much to be proud ofdsu* has much to be proud ofdsu* has much to be proud ofdsu* has much to be proud of
Joe, that was quick bro! Post it on the other place we're on. I'm sure people will be interested especially those who saw it at Best Buy!
Old Aug 5, 2012 | 12:22 AM
termsheet's Avatar
termsheet is infamous around these parts
Price and mileage please
Old Aug 5, 2012 | 02:04 PM
skeeter's Avatar
skeeter has a reputation beyond reputeskeeter has a reputation beyond reputeskeeter has a reputation beyond reputeskeeter has a reputation beyond reputeskeeter has a reputation beyond reputeskeeter has a reputation beyond reputeskeeter has a reputation beyond reputeskeeter has a reputation beyond reputeskeeter has a reputation beyond reputeskeeter has a reputation beyond reputeskeeter has a reputation beyond repute
It's on his ad. 100k with 18k miles
Old Aug 5, 2012 | 08:24 PM
Nick-NY's Avatar
Nick-NY is a splendid one to beholdNick-NY is a splendid one to beholdNick-NY is a splendid one to beholdNick-NY is a splendid one to beholdNick-NY is a splendid one to beholdNick-NY is a splendid one to beholdNick-NY is a splendid one to behold
I'd love to buy this but its not the correct color for me. GLWS
Old Aug 6, 2012 | 08:35 AM
str8blst's Avatar
str8blst Is a GOD !str8blst Is a GOD !str8blst Is a GOD !str8blst Is a GOD !str8blst Is a GOD !str8blst Is a GOD !str8blst Is a GOD !str8blst Is a GOD !str8blst Is a GOD !str8blst Is a GOD !str8blst Is a GOD !
Bump for a killer car! I've seen this one in person and if I was in the market I'd pick this up in a heart beat! GLWS!!!!
Old Aug 6, 2012 | 11:27 AM
911Konigin's Avatar
911Konigin has much to be proud of911Konigin has much to be proud of911Konigin has much to be proud of911Konigin has much to be proud of911Konigin has much to be proud of911Konigin has much to be proud of911Konigin has much to be proud of911Konigin has much to be proud of911Konigin has much to be proud of911Konigin has much to be proud of
Too bad I don't have the money ~ GORGEOUS!!
Old Aug 6, 2012 | 05:25 PM
Lennon31987's Avatar
Lennon31987 has a reputation beyond reputeLennon31987 has a reputation beyond reputeLennon31987 has a reputation beyond reputeLennon31987 has a reputation beyond reputeLennon31987 has a reputation beyond reputeLennon31987 has a reputation beyond reputeLennon31987 has a reputation beyond reputeLennon31987 has a reputation beyond reputeLennon31987 has a reputation beyond reputeLennon31987 has a reputation beyond reputeLennon31987 has a reputation beyond repute
damn! saw this car a few times over the last few months, real quick turn around. gl with sale
