Track Car E36 M3 Coupe with New LS2 Stroker
For Sale Race Car/Track Car E36 M3 Coupe with New LS2 Stroker
Year: 1997
Make: BMW
Model: M3
Price: $46000
Mileage: 50
Color: White
Location (State): FL
Transmission: Manual
Drivetrain: Rear Wheel Drive
This Car is complete and readyto be taken to the track
Also selling my open trailer but only after the car is sold, or as apackage deal with the car
The Traileris 25ft, double 7k axles, new winch, new tires, new wiring, new brakes andbearings
Asking price for the trailer is US-$ 3,500.00
1997 E36 M3 Coupe – Race Car (+/- 2750lbs)with new LS2 build Stroker motor (485 whp/511wtq)
Asking price: US-$ 46,000.00 (over $ 90,000invested)
Contact :mike_2727@live.com
Video (walk-around) : http://www.streetfire.net/video/walk-around_2420155.htm
Some pictures + Dyno : http://www.streetfire.net/photo/378jpg_2124855.htm
Here are the specs:
1997 E36 M3Coupe – Race Car (+/- 2750lbs)
Full10-Point Roll Cage
ReinforcedSuspension points
Custom E46metal fender flares (welded)
New wiringthroughout the car
Hardlinesfor Fuel and Brakes
Lexan Rearand side windows
Largeadjustable front splitter
2 FunctionalNaca ducts
Braillelightweight Battery (17lbs)
SPA FireSystem with 3 nozzles
HIDHeadlights
Driverwindow net
Custom DualSide Out exhaust
Carbon FiberRear Wing
Front andRear Tow Hooks
Coolingducts from front bumper to Brakes, Starter and Alternator
Big Sway Bar(front) – OEM rear Sway Bar
Tiltonadjustable Pedal Assembly (Brake + Clutch)
SeparateMaster Cylinders for Front and Rear (no ABS)
In Car BrakeBias Control (F/R)
Custom Dashswitch panel
CustomExtended Steering Rack
Sparco QuickRelease Steering Wheel
CustomAluminum Floors (insulated) and Transmission tunnel
Recaro PolePosition (FIA 2010) driver seat
SchrothProfi-II 6 / 6 point Harness (FIA 2011)
PassengerBlitz Race Seat
PassengerWillans 6 point Harness
Suspension:
KONI SAShocks
HypercoilSprings 600lbs (F) / 700lbs (R)
GroundControl Camber Plates
Eibach FrontSway Bar – OEM Rear Sway Bar
TurnerAdjustable Rear Camber Arms
Solid mounts
Drive Train:
New GM LS2 motor (only dyno and 1 DE at Homestead +/- 50 milesdriven)
Fully build Stroker
Wiseco Pistons
Eagle forged Rods (H-Beam)
Eagle forged Stroker Crank
Custom grind Comps Cam
Comps Cam pushrods
Lunati double valve springs
Clevite Bearings
ARP bolts throughout
Stage 8 locking nuts (headers)
L92 Ported heads
L76 Intake
90mm TB (DBW)
GM ECU with GM Engine harness
High Performance Starter
CTS-V 150 Amp Alternator
C5 Lingenfelter CAI
K&N Air Filter
Custom Headers (Nahrod) with Jet HotCeramic coating
Custom CNC Motor and transmission mounts(Nahrod)
Custom Drive shaft / steering rack (Nahrod)
Dual In-Tank Fuel Pumps
New SLP High Performance Oil Pump
New PRW High Flow Water Pump
Mishimoto Aluminum Radiator
3000 cfm Radiator Fan
FBody Oil Pan with Improved Racing Baffle
T56 6-Speed Transmission
QuarterMaster Button lightweight Flexplate
QuarterMaster Triple 7.25” Clutch, hydraulicwith remote bleeder / reservoir
New Canton 3 Quart electronic Accusump (notyet installed)
New Canton Remote Oil Filter
New Oil Cooler with Fan
3.38 LSD Rear Differential with Rogue DiffCover
Rear Diff Oil Cooler with Fan and pump
Brakes (no ABS):
New StopTech Race Kit (custom piston setup)4 piston 14” front
New StopTech Race Kit (custom piston setup)4 piston 13” rear
New CarboTech RP2 (front) / XP10 (rear)pads
In Car Brake Bias Control (F/R) and in car fluidreservoirs
6 rims APEX ARC 8 – 18x10 with 295/30/18Hoosier R6 (light weight)
4 rims 18x8.5 spare for wets
Video and Data Acquisition:
TraqMate Classic Complete with Display
TraqMate RPM input module
ChaseCam PDR 100
ChaseCam SS1000 with 2 Bullet Camera’s (forDual Camera PiP recording)
Bluetooth ODB-II Scanner for custom Gauges– needs a 7” Android Bluetooth (not included Tablet (+/- $ 200) + Torque Pro program ($ 6)
Miscellaneous:
In Car mounted Battery Tender
In Car Rust Stop Device (to be used duringstorage)
Spares:
BMW 3.91 LSD Rear Differential
2 – New 255 lph In-Tank Fuel Pumps
Spare Mishimoto Radiator Fan
Miscellaneous Chasecam parts + extra (3rd)Bullet Camera
GM Stock LS2 heads
GM Stock LS2 Intake
GM Stock LS2 Injectors
M3 - LS2 - E36 - Track Car - Race Car
I do not need to connect to any BMW harness, we made a custom harness from the engine backwards, seperate fuel system, no ABS, no nannies etc
Mike
Thanks for the info. Im running a Motec in my E46 M3 that has an LS6 and was curious what you was running in your LS equipped BMW.
GLWS, there is nothing like German handling paired with american muscle, its just brilliant.
Thanks, sounds nice E46 with LS6, how much power are you making ?
Yes the combination of German handling and American Muscle is mindblowing, the torque is out of this world, I can be basically in any gear and shoot out of turns like a rocket
Mike
If you ever want to go for a build like this, better buy it finished, I can tell you it takes a lot of time and $$$ to finish it properly
I find it strange nobody jumps on this I am selling for less than half of what was put in
Mike
Mike
