2000 Audi S4 Stage 3 Nogaro blue Las Vegas
Old Oct 24, 2015 | 09:27 PM
Claytondollente's Avatar
Claytondollente is infamous around these parts
Year: 2000
Make: Audi
Model: S4
Price: $13500
Mileage: 161000
Color: Nogaro Blue
Location (State): NV
Transmission: Manual
Drivetrain: 4WD & AWD
2000 Audi S4 Nogaro Blue Stage 3+
2000 Stage 3+ Audi S4. Nogaro Blue.161,XXX miles.
$13500 OBO
UPDATED 15 DEC 2015
Did valve cover gaskets, cam caps, cam plugs, half-moon gaskets (Blau parts valve cover kit enhanced)
Engine-
-SRM K24 Turbos / SRM oil lines
-DAZ tuned 91/E85 currently (have both files) must retune after meth kit install.
--boost spikes at 30 PSI holds at 28 PSI
-Walbro 485 Fuel Pump
-Devils own Methanol Kit- dvc-30 stage 2 (needs to be installed) with dual d05 nozzles to APR bi Pipe
-- 6 gallon tank in trunk
-ICM delete
-750cc Injectors
-APR Bi-pipe
-Forged 007 black diverter valves
-AWE Side mount intercoolers
-3? to 2.5" SSAC Down pipes
-2.5" Custom Magnaflow dual exhaust
-Goetze Piston rings 10/14/15
-Valve cover gaskets 12/14/15
- Half Moon gasket and cam caps 12/14/15
-All coolant hoses replaced 6/16/15
-Powersteering hoses replaced 6/17/15
-New Bosch Alternator 05/07/2015
-Serpentine Belt replaced 09/11/2015
-RPM rods
-New Clutch Slave cylinder with Stainless Steel braided line 5/15/2015
-Porsche coolant and oil cap
-034 intercooler silicone hoses
-new N75 07/23/15
-Bosch Platinum Spark Plugs 08/04/2015
-New AUX fan Pulley / aux fan clutch / aux fan 09/10/2015
-F hose delete
-Spider Hose DIY mod
-new N75 08/20/2015
-Rotella T6 Motor oil
-Bosch MAF sensor
Suspension/Brakes /Drivetrain/Trans-
-Clutch Net 6 puck clutch
-17z Porsche Brakes (front) w/ Hawk Brake pads changed 08/03/2015
-Stainless Steel Brake lines
-KW ST Adjustable Coilovers
-034motorsport density line control arm kit 02/14/2015
-Rebuilt driver side axle torn boot 08/15/2015
-Neuspeed rear sway bar
-AWE Drivetrain Stabilizer
-034 Street Density Motor mounts 09/21/2015
-JHM Short throw shifter
-realignment done by arrow frame alignment
Exterior -
-LLTek RS4 Mesh grills on bumper
-re-sprayed hood, bumper, and fenders
-Headlight washer delete on bumper (sealed with OEM material no bondo)
-18x9.5 ET40 ESM-008 (special drilled 5x112) wheels/w 15mm hubcentric spacers all around (No Curb Damage)
-Wheel locks
-Cupra R lip
-white LED plate lights
-Depo E-code Headlights D2S 6000k
-RS4 original Front Grille
-Silver Painted Side Mirrors
Interior-
-New A/C blower motor 08/16/2015
-Podi digital boost/AFR gauge(innovate) w/APR gauge pod center vent
-Kenwood Double Din touch screen
-Black leather/Blue Alcantara interior
-All Weather floor mats
-Black Alcantara shift boot w/ blue stitching
-Greddy Turbo Timer
-Aftermarket rearview mirror
-New Rear window regulators replaced with bolts instead of blind rivets 09/17/2015
-Fitted Windshield sun reflector
Bad-
-small tear rear passenger side seat of leather
-heater core bypassed (heater not working)
-caliper paint peeling off
-roof top paint fading (could be paint corrected)
Reason for Sale is to buy a house.
Title in Hand; Clean. All maintenance has been done by previous Audi tech who works out of his garage. I have not got the chance to dyno it. I fixed all the problems on this thing. My loss, your gain.
No test drives unless cash in hand. Serious inquires only! Please don't waste my time. If you have any more questions feel free to contact me at 702-202-eight 2 zero 4.
Old Dec 15, 2015 | 10:28 PM
price drop
wastedyolk
Sep 23, 2015 05:35 PM
vogz
Sep 22, 2015 12:38 PM
richard181
Bentley
Sep 21, 2015 10:35 AM
nick-seattle
Sep 18, 2015 08:14 AM
