1993 Fully built Single Turbo Supra
Year: 1993
Make: Toyota
Model: Supra
Price: $44000
Mileage: 97000
Color: Red
Location (State): OR
Transmission: Automatic
Drivetrain: Rear Wheel Drive
Mileage: 97k body (3k miles on driveline engine/transmission/battery/turbo/alternator/injectors/brakes)
Cost: $44,000 OBO
Car was designed to be used on the street with no compromising. No cages, no aftermarket body panels, no accidents, no sacrificing air conditioning or power steering. It has it all. My dream car is a Bugatti Veyron so I had the car built up to the point where the acceleration is the same as a Bugatti Veyron.
If you don't desire that type of acceleration and want to take it easy simply flip a switch and you are running low boost of 15psi instead of 26psi. Car is easy to launch. All the best parts were used so the engine and transmission are good for 1200HP. Great setup if you decide to put a bigger turbo on it. Car runs on premium pump gas or e85 fuel.
74mm Turbocharger good for 1000bhp
Turbo blanket and wrapped exhaust
Carillo HD rods
CP Pistons
272 Cams & BC springs titanium retainers
Greedy 4-row Front Mount intercooler
AEM engine management system
5 bar map sensor
ARP headstuds
Powerhorse racing crankshaft pulley
2 HKS super sequential Blow off valves
Exhaust:
Downpipe 3"
Greedy Power Extreme Exhaust
QT Electric Exhaust Cutouts with 2 wireless key-chain controllers. Car will sound insane when opened quiet when closed.
Fuel:
Tripple fuel pump setup good for 1300HP
1200cc RC injectors
Aeromotive fuel pressure regulator
Water/methanol injection (hasn't been used in years took fuse out)
Drivetrain:
Custom built 4l80e manual valve body transmission setup good for 1200hp
Billet input shaft
Transgo Stage 3 kit
Precision industries 5 disk lock up torque converter Vigilante. Shifter button activated
Mickey Thompson tires
B&M shifter
Solid driveshaft
Dedicated Transmission cooler and fan
Has more mods but these are the main components. Originally a twin turbo.
503-975-6543
Wealth Manager
Aug 8, 2016 05:13 PM
