engine replacement twice
Old Mar 23, 2016 | 11:02 AM
pabafree1995's Avatar
pabafree1995 is infamous around these parts
Hey fellas - i have an 08 targa 4s, purchased CPO 2010. shortly after buying, discovered scored #6. car was with Porsche for 6 weeks, and they replaced w rebuilt from factory.I've put ~ 25,000 miles on that engine, and last few weeks noted white plume from exhaust. dealer calls me now and says its due to scored cyl#6 and they are calling extended warranty co (3rd party ) to get approvals for rebuild from Porsche.
wondering if anyone aware of the same car having this kind of luck....!
definitely disappointed if this truly in the case.
thanks for any comments/
Old Mar 23, 2016 | 11:56 AM
JCD911S's Avatar
JCD911S is just really niceJCD911S is just really niceJCD911S is just really niceJCD911S is just really nice
What kind of oil have you been using and what intervals have you been changing it at?
Old Mar 23, 2016 | 02:39 PM
thanks - done at dealer mobil 0w-40 i believe. intervals ~5k with additional quarts as needed.
Old Mar 23, 2016 | 06:36 PM
myw's Avatar
myw
myw is a splendid one to beholdmyw is a splendid one to beholdmyw is a splendid one to beholdmyw is a splendid one to beholdmyw is a splendid one to beholdmyw is a splendid one to beholdmyw is a splendid one to behold
does your car used during freezing cold winters?
Old Mar 24, 2016 | 05:09 PM
Gpjli's Avatar
Gpjli has much to be proud ofGpjli has much to be proud ofGpjli has much to be proud ofGpjli has much to be proud ofGpjli has much to be proud ofGpjli has much to be proud ofGpjli has much to be proud ofGpjli has much to be proud ofGpjli has much to be proud ofGpjli has much to be proud of
Sooo....you are sure they used a rebuilt motor from Porsche. Could not be they rebuilt your old motor using same block/heads? If so the odds are pretty much against this. Very bad luck. Lucky you have warranty.
TRBOSPD
New Member Introductions
Apr 26, 2016 07:01 PM
Never Enough
Mar 29, 2016 03:30 PM
slayer of souls
Lamborghini
Mar 23, 2016 11:30 PM
CJin25552
Feb 23, 2016 08:01 PM
albert@velosdesignwerks
Feb 22, 2016 03:23 PM
