Installing new model steering wheel into 970 ?
Old Jul 31, 2017 | 10:56 AM
hollynitro's Avatar
hollynitro is infamous around these parts
Hi Guys ,
anyone know that this is possible ??
just saw someone post this picture ...
pic credit to @liybalance
Old Jul 31, 2017 | 02:12 PM
allroadusa's Avatar
allroadusa has a spectacular aura aboutallroadusa has a spectacular aura about
Yes, it seems the author of this pic has found a way : https://gpsadapter.us/products/stmv1-971
Old Jul 31, 2017 | 02:35 PM
cvprez's Avatar
cvprez is infamous around these parts
The new wheel is way nicer, but this is going to be an expensive proposition. $599 for the adapter, probably $2000 for the new style wheel and then whatever a shop/dealer is going to charge to perform the swap and install the new coding. All told I'm sure it's a $3000+ upgrade which is a little tough to swallow just to get paddles and multi-function combined
Old Jul 31, 2017 | 06:36 PM
negb's Avatar
negb is infamous around these parts
Question
Is pre-facelift and facelift models has differences in steering wheel connections ?
Old Jul 31, 2017 | 11:31 PM
amgpan's Avatar
amgpan is infamous around these parts
The thing i want to know is, in the Multi Function display in the pic above, where the boost gauge is, there is a little pic of a turbo. On my car, there is no pic of a turbo. Its just blank, with a boost bar graph/ gauge. How do i get the little pic of the turbo. Looks cool.
Other question is, how do you get the picture of the speed limit in the display too. Thats pretty cool.
Old Aug 1, 2017 | 07:24 AM
hollynitro's Avatar
only the adapter cost $599. ouch !! That adapter is 3rd party or from Porsche ??
Also , after installing the adapter .. All the functions from new model steering wheel is available to use ??
This is the Steering wheel i found , only $749
https://www.suncoastparts.com/product/SKU971CFSW.html
Old Aug 2, 2017 | 08:05 PM
amgpan's Avatar
To that price from Suncoast, you would have to add an airbag.
Old Aug 3, 2017 | 09:18 AM
hollynitro's Avatar
with the airbag , it would be $1,350
Old Aug 3, 2017 | 10:16 AM
Just A GTS's Avatar
Just A GTS has a spectacular aura aboutJust A GTS has a spectacular aura aboutJust A GTS has a spectacular aura about
It also does not have the **** that switches to sport, sport+, etc (if you had sport chrono).
Old Aug 3, 2017 | 10:55 AM
hollynitro's Avatar
you can pick the option of that **** when you purchased the steering wheel . With or without Sport Chrono .
Old Aug 6, 2017 | 10:59 AM
hollynitro's Avatar
Originally Posted by liybalance
https://youtu.be/R5o_NGnRkDM
Mode switch dial can't support change S S+ now,because old clock spring control module didn't support process mode switch dial signal.I'am developing process and transfer dial switch signal to center console adapter by Bluetooth,center console adapter inject S S+ signal to control module.This feature will support at 991.1 and 958 first,970 center console button module works mechanism restricted,need more research.
https://gpsadapter.us/blogs/news/my-...steering-wheel
Very Nice project !! i will wait until the dial switch is functional
Also , the pedal shifter is working for this new steering wheel ?
Old Sep 1, 2017 | 09:34 PM
atwong1's Avatar
Emerging Sponsor
5 Year Member
atwong1 is infamous around these parts
Before and After...What color top center band would you prefer if it were you?
My 2014 came like the picture above. I got this red one below as a gift. To make this work, I had to order the adapter kit from Paul Li. Thank you Paul.
To keep the heated function, I have to replace this little surface mount resistor.
Red is nice, but my interior is black. I have to do something about it. Oh well, since it's a e-Hybrid, might as well go green.
After hours of struggle, here is the final product. Now that I am a pro, I am available to do the install for anyone who are interested in the U.S. Please PM Paul or myself. If you are in Atlanta, I can even do the complete job for you.
Old Sep 2, 2017 | 01:40 PM
hollynitro's Avatar
Have a big challenge developing dial support,panamera and macan connect sport mode keyboard to central control module use MCU to MCU link(Maybe use SPI or I2C),can't find those two MCU chip data sheet.It's NEC chips.Anybody could help me find chips data sheets?
Can't find data sheets about this button control chip.
NEC MCU,can't find data sheets about this MCU
Oh wow , hopefully someone can help u with the problem !!
i don't understand anything about that .. so sorry
Old Sep 3, 2017 | 09:52 PM
atwong1's Avatar
Emerging Sponsor
5 Year Member
Great job,Your hand skill is so good!How long completed alcantara cover?
I redid it three times. First time, took me 12 hours, last time took 4 hours. I think I did it too fast and it's only 90% perfect. I plan to redo it again to get it to 100%. I know it will take 5 hours. This does not include taking all the parts off the steering to expose the skeletons, measure exact location for the center mark, and reassemble it. Those should take about 1 to 1.5 hours total.
I think this part was the hardest part of all. Need a lot of measuring, a lot of patience, and put blisters on my fingers.
The second hardest of this project was the heated steering control switch. Replacing the surface mount resistor by hand is very very tricky. I thought it's impossible by hand, and I hesitated. I have not soldered for a few years, so I took it to a local electronics shop to ask them to do it, and they said they would likely burn the neighboring components. They said they will let me use their equipment. I looked and their "professional equipment" was not even remotely as good as mine. Thanks to a lot, a whole lot of encouragement from Paul. I am still excellent in soldering.
Old Aug 27, 2018 | 01:02 PM
Elberoth's Avatar
5 Year Member
Elberoth is infamous around these parts
Another successful retrofit, using the GPS adapter. This time on friend's 2016 Panamera, with heated steering wheel. Everything works of course.
New:
Old:
Again, service from the GPS guys was exemplary.
