Chime on above 75MPH
Old 01-18-2019, 08:04 PM
jayi836's Avatar
jayi836 will become famous soon enoughjayi836 will become famous soon enough
Just replaced my PCM2.1 with an Alpine iLX-207 HU and the HUR NAV-TV210, 2008 997TT with the Bose Amp.
Now I have my seat-belt chime coming on at 76MPH and off at 71MPH WTH!!!
Anyone have any thoughts I have a Durametric Pro and went into the instrument cluster and turned all the chimes off.
Another interesting thing the car is equipped with the Sports Chrono it hasn't worked since i purchased the car in August 2018 not it does work.
Old 01-19-2019, 06:17 AM
Petza914's Avatar
Petza914 has a reputation beyond reputePetza914 has a reputation beyond reputePetza914 has a reputation beyond reputePetza914 has a reputation beyond reputePetza914 has a reputation beyond reputePetza914 has a reputation beyond reputePetza914 has a reputation beyond reputePetza914 has a reputation beyond reputePetza914 has a reputation beyond reputePetza914 has a reputation beyond reputePetza914 has a reputation beyond repute
You sure it's not the speed limit chime ? Does the dash display a fasten seat belt icon when the chime is happening?
Old 01-19-2019, 08:02 AM
jayi836's Avatar
Speed limit chime has a different sounds also alerts you in the multi function display. I unbuckled at 65MPH and the seat belt warning on the dash let's me know and same chime goes off.
Next test or step is to reinstall the PCM.
Old 01-19-2019, 01:59 PM
jayi836's Avatar
I pulled the Alpine and drove with the stock PCM then no PCM, no change. Must be a malfunction of some kind.
I also removed the factory XM, 6CD changer and NAV system don't think it has any affect as its fiber optic and power. Looped the Bose amp back in.
Old 01-19-2019, 07:24 PM
jayi836's Avatar
no seat belt icon I suspect this chime is used for other warnings like head lights on and key in ignition. Very Bizarre I will need to get some one with a piwis 2 or dealer to diagnose this live to figure out the trigger.
Old 01-19-2019, 08:18 PM
jayi836's Avatar
SOLVED!!
Reset the ECU and all good now.
Porsche997TT
07-30-2018 08:22 AM
Tiptronicus
08-03-2011 11:25 AM
Antz_997s
03-01-2008 04:26 PM
Quick Reply: Chime on above 75MPH
