Mysterious Tail light issue I can't figure out
Old 11-18-2019, 02:51 PM
first.last's Avatar
first.last is an unknown quantity at this point
Hi all, I tried searching but couldn't actually find anyone who had a solution to this problem. Here's the symptoms:
1) Rear driver tail light doesn't light up, warning on in dashboard
2) Passenger side works fine
3) Reverse, blinker, and fog light all work
4) When I unlock the car or turn the lights on, driver side tail light comes on for 1 second then turns off
Here's what I've already tried:
1) Swapped left and right tail lights, verified that it works on the other side
2) swapped all bulbs in both taillights, made no difference
3) Cleaned electrical contacts
4) Checked fuses. They're fine and like I said the light does come on briefly and all other lights work
5) Replaced headlight switch, made no difference
Has anyone else seen this before or have a solution? Since it comes on for a second and then turns off and all the other lights work, it doesn't appear to be an intermittent issue or a wiring issue in between the switch and the light but rather some other electrical problem.
Old 11-19-2019, 07:28 AM
Petza914's Avatar
Petza914 has a reputation beyond reputePetza914 has a reputation beyond reputePetza914 has a reputation beyond reputePetza914 has a reputation beyond reputePetza914 has a reputation beyond reputePetza914 has a reputation beyond reputePetza914 has a reputation beyond reputePetza914 has a reputation beyond reputePetza914 has a reputation beyond reputePetza914 has a reputation beyond reputePetza914 has a reputation beyond repute
Disconnect the battery for 10 minutes, then reconnect it. DON'T LATCH THE FRUNK WHILE THE BATTERY IS DISCONNECTED.
This will reset the bulb control module and function may magically return.
Old 11-19-2019, 08:59 AM
first.last's Avatar
Thanks for the reply, gave that a shot and no luck unfortunately.
I did notice today that the spoiler is stuck up and the engine compartment light doesn't work...although I'm not sure if these are separate issues and my spoiler hydraulics and engine bulb happened to go out now.
Is the rear control module in the passenger side suspension area? Is it possible the module went bad or there is some coding issue?
Old 11-24-2019, 10:45 AM
964hans's Avatar
964hans will become famous soon enough
Probably it is indeed the CU REAR
Regards Hans
Old 12-08-2019, 01:39 PM
first.last's Avatar
Just to update this in case anyone else comes looking for a solution. I replaced the rear module under the front driver seat and rear lights seem to be working again.
Old 12-08-2019, 11:41 PM
Hella-Buggin''s Avatar
Hella-Buggin' has much to be proud ofHella-Buggin' has much to be proud ofHella-Buggin' has much to be proud ofHella-Buggin' has much to be proud ofHella-Buggin' has much to be proud ofHella-Buggin' has much to be proud ofHella-Buggin' has much to be proud ofHella-Buggin' has much to be proud ofHella-Buggin' has much to be proud ofHella-Buggin' has much to be proud of
Have you checked for rodent damage. The love to eat wiring.
Old 12-15-2019, 08:46 PM
first.last's Avatar
Nothing wrong with the wiring...looks like the rear module just went bad. All good now!
Old 05-02-2024, 09:20 PM
997CarreraCab's Avatar
997CarreraCab is on a distinguished road
I have a similar issues excep mine don’t turn on for a second. The reverse blinker and fog light work.
Old 05-03-2024, 07:15 AM
Can I have the part number please?
audiomutt
Cayenne 958
02-25-2021 03:02 PM
kdiro
10-04-2017 08:48 AM
eurowolfgang
10-05-2015 07:43 PM
RobboT
10-07-2012 12:25 PM
Quick Reply: Mysterious Tail light issue I can't figure out
