997.1 TURBO 1100CC fuel injectors with height adapters
1100cc fuel injectors with height adapters
Link:
https://www.protomotive.com/wp422/pr...v=7516fd43adaa
Info:
-Purchased new from Protomotive on 10/17/2022.
-Never used or installed or plugged in.
-Brand new in box (box was opened for pictures).
-Selling because I was planning on tuning with E85 in my car but don’t want all that drama associated with it.
From Protomotive’s site:
Grab a set of 1100cc fuel injectors for your project. Perfect for 996T, 997.1T, and even E85 993TT projects! Awesome on 996 and 997.1 turbos that have reached their fueling limit with oem injectors or for E85 conversion. Turbo Cayman, Turbo Boxster, 997 Carrera Turbo upgrade? These are drop-in’s for these as well.
Correct o-ring to o-ring dimensions and diameter with height adapters on 996/997.1TT.
Sold in flow matched sets of 6.
52.8mm o-ring to o-ring dimensions. 14mm lower o-ring, 13.5mm upper oring.
Standard Bosch electrical connectors, so no adapters or messy wiring!
12 ohms for a perfect connection to your oem ecu.
Max 11-1200hp range on pump/race fuels or 780hp range on E85 at 3.8 bar. Can run 5 bar for even more flow!
These retail for $1,140.00 + shipping. Offered here for for $1,100.00 shipped in the lower 48.
****The description of these from Protomotive's website suggest that this item MIGHT also fit and plug into 996 Turbo's as well. Please research and verify****
spitfun
Aug 7, 2021 08:52 AM
Nerdhotrod1
Jan 1, 2020 11:33 AM
