Bentley Continental GT 2004 with emissions issues
Hi all,
I’m still looking for a Bentley Continental GT. I’ve come across another one for sale in Scotland(there’s not too may up here). Anyway, I'm looking at a 2004 model and this one seems ok but it failed its 2024 annual UK MOT(Emissions/safety check) on CO emissions and Lamda incorrect. Seller said it was fixed by adding fuel additive(he didn’t say what type) and driving a few hundred miles. The MOT website does show he done a few hundred miles in between MOT failure and MOT pass. I don’t take anything for granted when buying cars and I just want to check with the forum that adding fuel additives could indeed potentially fix lambda/CO emission problems. Can anyone comment?
Seller also said the few hundred mile drive also sorted a ‘dragging’ rear calliper!! It went from ‘dragging excessively’ to ‘dragging, but not excessively’ in the MOT tests. I’m not to worried about this as I can check this if I view the car and there are repair kits for $50 on ebay. Do you need any diagnostics etc to change the calliper/bleed the brakes?
Thanks again
Tony
Thanks again
Tony
Hi all,
Thanks again
Tony
Thanks again
Tony
Cheers.
Ive been thinking of selling mine. Imine.08 GT Speed. I had Bentley Glasgow remove the engine and check all vac lines . Replaced oil coolers and pipes. Relocate n75 valves. Both turbos fully reconditioned. Gear box and TQ fully reconditioned. New Starter. New egt sensors. . As I use the car regularly in Europe I spent 20k on all the usual areas of possible potential failures. Bug im hankering on another Cosworth. The car has a lot more done to it which I can pm you with if required including price etc.
Frank
Frank
Cheers.
Frank
Frank
Can you answer any of my questions?
Im not sure one way or another if an additive could cure the emissions? But it would be good to get a lambda reading now as if is.
