Tech / How To
Bluetooth Help !
Old Jul 31, 2009 | 04:48 PM
bosco42's Avatar
bosco42 is a splendid one to beholdbosco42 is a splendid one to beholdbosco42 is a splendid one to beholdbosco42 is a splendid one to beholdbosco42 is a splendid one to beholdbosco42 is a splendid one to beholdbosco42 is a splendid one to behold
Bluetooth Help !
My bluetooth has been working fine up until today.
Now when i go to make a call the bluetooth connects but I can not hear anything and the other person cant hear me...the mute button is not on so thats not the problem...any ideas ?
Old Jul 31, 2009 | 05:23 PM
Zlatko's Avatar
Zlatko has a brilliant futureZlatko has a brilliant futureZlatko has a brilliant futureZlatko has a brilliant futureZlatko has a brilliant futureZlatko has a brilliant futureZlatko has a brilliant futureZlatko has a brilliant futureZlatko has a brilliant futureZlatko has a brilliant futureZlatko has a brilliant future
It can be a wide range of issues. Try bonding the BT headset to another phone to see if you get the same issue. Try bonding your phone to another BT headset.
Try resetting the BT headset, and also see if you can clear your phone's BT history. Ez.
Old Aug 1, 2009 | 04:26 AM
bosco42's Avatar
I am referring to the factory bluetooth in my 2009 C2S
Old Sep 21, 2009 | 12:39 PM
bestint's Avatar
bestint is infamous around these parts
warranty issue. like the other guy said, try pairing another phone. if that doesnt work then you got a bad unit. take her back to the dealer. should be under warranty.
Old Sep 23, 2009 | 09:30 AM
SoCal C4S's Avatar
SoCal C4S has much to be proud ofSoCal C4S has much to be proud ofSoCal C4S has much to be proud ofSoCal C4S has much to be proud ofSoCal C4S has much to be proud ofSoCal C4S has much to be proud ofSoCal C4S has much to be proud ofSoCal C4S has much to be proud ofSoCal C4S has much to be proud ofSoCal C4S has much to be proud of
Concur with bestint. Try different phones, and if all else fails, call the Dealer or go see them. May be a fuse...
jabed92694
Apr 3, 2016 11:31 AM
7thsign
Dec 12, 2015 07:43 PM
nephew
Sep 30, 2015 06:57 AM
Oscar 987
Sep 29, 2015 04:57 PM
