Tech / How To
help removing bumperettes!
Old Aug 30, 2009 | 08:31 AM
lbmw's Avatar
lbmw is infamous around these parts
anybody have a diy in painting and removing bumperettes?
Old Sep 3, 2009 | 10:12 PM
justatoy's Avatar
justatoy Is a GOD !justatoy Is a GOD !justatoy Is a GOD !justatoy Is a GOD !justatoy Is a GOD !justatoy Is a GOD !justatoy Is a GOD !justatoy Is a GOD !justatoy Is a GOD !justatoy Is a GOD !justatoy Is a GOD !
You will need to remove the bumper all together...at least for a 997!
I would guess that the 996 would be the same.
The bumperettes are just pressed in with tabs on the back side so you will to push those out...also there is a plastic pin holding it on the backside too!
Hope that helps...and I hope you were talking about a Porsche!
Judging by your previous posts you are!
Stacy
Old Sep 3, 2009 | 10:32 PM
lbmw's Avatar
i was looking at it looks like i just need to remove the bumperette cover to exposed the bolts. i tried to unsrew it but too tight. i have a feeling i dont have to remove the rear bumper for 996. thanks for the info anyways. i just pick up my 996tt a couple of weeks ago.
Old Oct 22, 2009 | 10:11 PM
fotostars's Avatar
fotostars has much to be proud offotostars has much to be proud offotostars has much to be proud offotostars has much to be proud offotostars has much to be proud offotostars has much to be proud offotostars has much to be proud offotostars has much to be proud of
Correct, no need to remove the bumper. I just upgraded to painted ones recently. Just unscrew the bolt and then lift the bumperette, it should come out very easily...
Old Jun 14, 2010 | 11:21 PM
silverlight's Avatar
silverlight is infamous around these parts
helpful tip, thx. About to do the same and was wondering about procedure. Just ordered a painted set from bumperplugs.com
NIKAS
Aug 20, 2019 07:53 PM
markj
911
Apr 7, 2016 05:44 PM
AM v12v
Sep 7, 2015 02:17 PM
Wildcat1212
Sep 7, 2015 11:31 AM
