DIY 997 Series Porsche 911s
#80
Any newly acquired car I have gets clear headlight and driving light covers installed as a DIY. These are usually available for any car from Weathertech and cost a LOT less than having to replace the headlight or driving light lens.
Update: I just installed grills from Dunsport last night. Easy-peasy 40 minute project if beer with visiting neighbor isn't involved. If neighbor visits with a six-pack, add another hour or so.
#81
997.2 Cabin Air Filter
The filter for the 997.2 is concealed in the luggage bay by the upper right plastic panel (near boot hinge), slipped beneath the right luggage plastic trim which is held by 3 velcor pads & a slip joint at the front edge. You'll need a t30 torx drive for the 4 stainless screws that restrict access. The filter lifts out with minimal effort after the clip holding the edge nearest the drivers side is released.
I inspected and cleaned the surfaces; my filter was clean but needed a careful vacuuming of the outer (upper) surface. Re-install requires care to prevent damage due to bending the filter and watch for the two wires nearby. The clip require that the filter be fully settled (watch the back edges).
With knowledge this is a 15 min. exercise.
Maybe this could be added to the DIY thread but I've made no images.
#82
Today I completed a 3-weekend project on my 2007 C2.
- Alan
- New X51 Headers
- New NHP 200-Cell Cats
- New NHP Sport Mufflers
- New Dual Chrome Tips
- New Denso IK22 Spark Plugs (note: gap had to be adjusted from 0.8 to 1.6mm)
- New Beru Ignition Coils (hadn't planned on doing these; lesson learned)
- New IPD 82mm Comp Plenum
- New GT3 Throttle Body
- New BMC Air Filter
- New Serpentine Belt
- Softronic ECU Flash
- Sore muscles, a few bumps on my head, and a bruised thumb
- Alan
#88
#89
any help w/ spring install on a cab?
after searching I found this thread:
https://www.6speedonline.com/forums/...installed.html
but pictures are gone and looking for more of a step by step instructions if possible. Also, how do I get to the rears on a convertible
