Tech / How To
996tt. Can you remove pads without removing the caliper?
Old Sep 7, 2010 | 02:48 PM
S4Drifter's Avatar
S4Drifter is infamous around these parts
Question 996tt. Can you remove pads without removing the caliper?
Newbie question I know, but I appreciate any advice. In anticipation of a DE the day after tomorrow, I thought I would do a dry run replacing brake pads since the car is new to me.
I found a couple of videos that made it look insanely easy except that they were for the cayman S (oops).
I removed the pin, the spring and the sensors. Spread the pads to push the pistons back and then... I still couldn't get the pads out. Do I need to remove the calipers to get the pads out?
I started following this writeup: http://www.heumann.com/bigred/index.html is it accurate?
Thanks!
Old Jan 24, 2012 | 05:03 PM
tgsmith4845's Avatar
tgsmith4845 is a jewel in the roughtgsmith4845 is a jewel in the roughtgsmith4845 is a jewel in the roughtgsmith4845 is a jewel in the rough
Hey S4, Was just reading through some old threads and saw your question re removing 996TT brake pads. Hopefully you've got your answer already, but if not, yes, you can remove the brake pads w/o removing the calipers. Super easy, just have to use a putty knife to release the anti-vibration backings if they're stuck together.
Tim
Old Feb 17, 2012 | 09:38 AM
function12's Avatar
function12 Is a GOD !function12 Is a GOD !function12 Is a GOD !function12 Is a GOD !function12 Is a GOD !function12 Is a GOD !function12 Is a GOD !function12 Is a GOD !function12 Is a GOD !function12 Is a GOD !function12 Is a GOD !
Agreed. I would bet the anti-vibration pads are stuck to the pad.
Old Mar 1, 2012 | 06:16 AM
DERBOOST's Avatar
DERBOOST is a glorious beacon of lightDERBOOST is a glorious beacon of lightDERBOOST is a glorious beacon of lightDERBOOST is a glorious beacon of lightDERBOOST is a glorious beacon of light
yup...super quick, nice thin puddy knife and there out
NIKAS
Aug 20, 2019 07:53 PM
markj
911
Apr 7, 2016 05:44 PM
John@SpeedTech
Sep 4, 2015 07:23 AM
ECS Tuning - VW
Sep 2, 2015 09:03 AM
