Tech / How To
996 TT Check Engine Light- Misfire
Old Oct 8, 2011 | 06:06 PM
jcam's Avatar
jcam is a splendid one to beholdjcam is a splendid one to beholdjcam is a splendid one to beholdjcam is a splendid one to beholdjcam is a splendid one to beholdjcam is a splendid one to beholdjcam is a splendid one to behold
When the check engine light came on, my mechanic plugged the car into his laptop and got a misfire reading. Since the car was not due for a plug change, he attributed the misfire to bad gas and drained the tank. That didn’t fix the misfire light from coming on and he accordingly changed the plugs. After changing the plugs the misfire reading still appeared which led to changing out the coil packs. That didn’t fix the problem either, so he borrowed an ECU from another TT and put it in my car…NADA. We’re currently scratching our heads wondering what is causing the problem. Anyone else experience this?
Old Oct 10, 2011 | 08:42 AM
HouseAutomotive's Avatar
HouseAutomotive is just really niceHouseAutomotive is just really niceHouseAutomotive is just really niceHouseAutomotive is just really nice
What are the fault codes for the check engine light?
Old Oct 12, 2011 | 05:12 PM
jcam's Avatar
Sorry about the delayed response. Spoke to the mechanic today and he didn't recall the numeric portion of the fault code and said that the description of the code read "misfire". He also said that the problem has been fixed and that it was a broken cam lift bracket and that when the car was attempting to shift into a higher lift cam, it was causing the "misfire reading".
Old Feb 14, 2012 | 08:17 AM
Arnie1's Avatar
Arnie1 has a spectacular aura aboutArnie1 has a spectacular aura about
it is the ignition coil on top of the plug that is the problem. It only does it on hard acceleration at high revs correct?
tropicatango
Jun 8, 2025 01:00 PM
Mini George
Jul 29, 2019 12:20 PM
Mini George
Jan 18, 2016 09:16 PM
oddjob142
Aug 24, 2015 05:49 PM
