Tech / How To
B&M short shifter
Old Jan 1, 2004 | 10:10 AM
996's Avatar
996 is infamous around these parts
Question B&M short shifter
I have installed a B&M SS and it's great. Should be original equipment as far as I'm concerned! The problem is, however, I CANNOT remove the shift **** and boot from the shifter rod, pole whatever you want to call it. I do not have the set screw version. What is the secret? The boot,****, rod/linkage/pole are already removed from the car, I just need to reinstall it on the new shifter.
Old Jan 2, 2004 | 04:37 PM
996's Avatar
Talking
I came to the conclusion that there is no "secret"...after alot of tugging, pulling, swearing and blood, sweat, and tears..I GOT IT... just for gp, if someone does know an easy way to remove the ****, please pass it on.
Old Jan 2, 2004 | 04:44 PM
TCM's Avatar
TCM
TCM is infamous around these parts
I was going to reply saying to just try and pull it off, but I was not sure that was the correct way to remove the **** (only have removed one and I forgot how we got it off). Most of the German cars tend to have the ***** on plastic clips that keep the **** from moving. But boy, they can be a bear to pull off, very tight. I am glad to see everything worked out ok for you.
Old Jan 2, 2004 | 05:05 PM
msindi's Avatar
TC - mine has the set screw...remeber designing a custom ultra short 6mm allen key ??
Old Jan 2, 2004 | 06:15 PM
996's Avatar
....."a bear", TC, THAT is an understatement!!
Old Jan 2, 2004 | 09:39 PM
TCM's Avatar
TCM
Mansour:
I do not remember, maybe I was detailing the paint when you pulled it off? Now that you mention the short allen key, I do have a vague remembrance of it.
996:
You are not kidding. The BMW 5 series is the same way. I had a black eye for two weeks after the damn **** finally came off and came up and hit me in the face!
steve harris
Jun 10, 2017 12:17 AM
turb0terr0r
Sep 29, 2015 05:47 PM
bongnation
Sep 25, 2015 02:58 PM
997zen
Sep 7, 2015 07:13 AM
