Aluminum lug nuts strong enough for AutoX?
Old Jun 28, 2009 | 08:58 AM
Lerxst's Avatar
Lerxst is infamous around these parts
I picked up Vertex' aluminum lug nuts to compliment the 15 mm adapters, but am a little concerned if they are strong enough for AutoX. I've found yes for AutoX and no for road racing so far... but looking for a little more assurance... any positive or negative experiences on the forum?
http://www.vertexauto.com/ShowItem/3...0Aluminum.aspx
Are there chorme (steel) lug nuts out there?
Old Jul 26, 2009 | 12:00 AM
Springgeyser's Avatar
Springgeyser is infamous around these parts
I can tell you my friend has been running aluminum lug nuts for AX and DEs for years without issue.
I personally would not trust it with all the lateral load on each wheel.
Old Jul 27, 2009 | 07:15 AM
driver8's Avatar
driver8 is infamous around these parts
I would go with the steel lug nuts for AX and DE's and save the aluminum for the street. I do not know of any chromed steel lug nuts.
Old Aug 8, 2009 | 05:19 PM
MJDRIVE's Avatar
MJDRIVE is infamous around these parts
I would immagine aluminum lug nuts are safe.
If you think about the dynamics of a cornering vehicle most of the load is being placed on the outside tyres and that energy is transfered to the car by the wheel hub as opposed to the lug nuts. The inside tyres are unloaded and in some extreme cases even carried in the air. Most of the force is carried by the wheel hubs in cornering.
You can always do your own testing. Do a run, pull them off and inspect for any type of deformation.
DLF
Cayenne 955/957
10
Feb 28, 2022 11:49 PM
Staff@WORLD
Feb 8, 2016 09:22 AM
Texas1
Sep 20, 2015 09:12 AM
zuman
Sep 3, 2015 08:27 AM
