mod delima, bucket seats, 18" track wheels or kw v3?
Old Aug 9, 2010 | 12:22 AM
rotaz's Avatar
rotaz has a spectacular aura aboutrotaz has a spectacular aura aboutrotaz has a spectacular aura about
I'm debating on getting the following items for my next track event, I wish I can purchase them all at once, but I don't want to hear it from my wife.
I'm thinking of getting the following in this order:
1. bucket seats - last time I was sliding around everywhere and had bruises on both knees.
2. Light weight 18" track wheels and tires - btw what tires do you recommend? NT-01 or R888? I have 19" lobsters wheels, but 19" tires are expensive to keep replacing.
3. KW V3 coilovers - I would do these first, but I already have PASM + cargraphic springs + RSS sway bars + drop links
I'm thinking the most noticeable mod would be the wheels + tires from the reduced rotational mass.
Inputs?
Old Aug 11, 2010 | 06:41 PM
mdrums's Avatar
mdrums Is a GOD !mdrums Is a GOD !mdrums Is a GOD !mdrums Is a GOD !mdrums Is a GOD !mdrums Is a GOD !mdrums Is a GOD !mdrums Is a GOD !mdrums Is a GOD !mdrums Is a GOD !mdrums Is a GOD !
I say get the seats to hold you better with a 6 point harness and HANS.
NT-01's have longer heat cycles....get Toyo RA1's if you can. R888 is not a bad tire like some say but they heat cycle out sooner.
Also get some Pagid RS29 Yellows nad Motul RBF660 brake fluid.
Then do the coilovers to complete eveything leter down the road.
Old Aug 11, 2010 | 06:46 PM
GT3 Chuck's Avatar
Administrator
don't get harnesses with the seats unless you have a roll bar...the harness and seat combo will keep you vertical in a roll over and squash your pumpkin...you are safer with the stock seat belt if no roll bar
Old Aug 12, 2010 | 12:36 AM
rotaz's Avatar
Thanks for the input, I'll most likely get some seats. I'm thinking of getting the ROTtec carbon fiber CGT reps, do you guys think ROTtec rep seats would be safe or should I stick with Recaros?
Old Aug 12, 2010 | 09:07 AM
Sales@Forged's Avatar
Sales@Forged has much to be proud ofSales@Forged has much to be proud ofSales@Forged has much to be proud ofSales@Forged has much to be proud ofSales@Forged has much to be proud ofSales@Forged has much to be proud ofSales@Forged has much to be proud ofSales@Forged has much to be proud of
Chuck is right....seats without harnesses and a roll bar is not a good idea.
Given that list, I would probably go wheels and tires, for most bang for the buck. The seats, bars, harness, and install is going to add up and might **** off the wifey.
Old Aug 22, 2010 | 03:03 AM
tofunin's Avatar
tofunin is infamous around these parts
You could try the CG lock as well as it attaches to your 3 point seat belt and makes it harness tight very affordable until you get the seats, bar, and harness
Old Aug 22, 2010 | 09:10 AM
Lysoleverywhere's Avatar
Lysoleverywhere is just really niceLysoleverywhere is just really niceLysoleverywhere is just really niceLysoleverywhere is just really niceLysoleverywhere is just really nice
You should start a thread on this..and make it a sticky!!
Old Sep 12, 2010 | 07:12 AM
ponzz's Avatar
ponzz is infamous around these parts
A little late, but were you getting a second set of wheels/tires to swap back and forth from street tires to track tires?
If you have dedicated track wheels, why not get Hoosier r6's? If you look around, you can get used Hoosiers for 18" wheels for around $70 and get at least 3-4 days out of them.
COBB Tuning
Jan 1, 2025 09:02 AM
GrantRR
Jun 28, 2018 03:33 PM
TrackOne
Aug 20, 2015 12:56 PM
pwdrhound
Aug 20, 2015 05:54 AM
