Hoosiers
Old Sep 28, 2011 | 01:12 PM
titangolf's Avatar
titangolf is infamous around these parts
Hoosiers
I have just purchased a 996TT that I plan on tracking. What pressures (hot) are guys running with Hoosiers on similar cars? Thanks for any input.
Old Oct 1, 2011 | 05:51 PM
vpmick's Avatar
vpmick is infamous around these partsvpmick is infamous around these parts
I drive a 997TT and I start with cold pressure of 28 front 30 rear and hot gets to about 38 front and 40 rear. This seems to be best for me from a performance and longevity standpoint. You will love the Hoosiers but man are they an expensive habit!
Old Mar 21, 2012 | 07:01 AM
jmcginty's Avatar
jmcginty is infamous around these parts
I just tracked a 996TT at VIR. I ran my R6s at 24 rear and 26 front. After adjusting the start pressures to this level, I achieved 40 PSI at the end of each run. That is the pressure where R6s are happiest. Hope this helps. Also, dont run R6s unless you have some negative camber. The R6s need about 3 degrees of negative which is what I run and they were wearing and heating up consistently across the tire surfaces.
VID997
97
Mar 20, 2018 02:23 PM
Turbo3.6
Sep 18, 2015 11:10 AM
greekc6
Sep 16, 2015 02:49 PM
JWrightPNH
Sep 14, 2015 01:15 PM
orbelo
Aug 30, 2015 12:26 PM
