track tires
Old May 4, 2013 | 04:10 PM
chbernat's Avatar
chbernat is infamous around these parts
track tires
I have a 2005 911 997 c2 and have currently on it c2s 19 inch rims on it with snows on them. Since its not the wider body it fills out the wheel well and fender.
They are
235/35/19
295/35/19
Now the question.
I am going to use these rims as track rims and have purchased the pilot sport cups for these
rims but 305/335/19 for the rears because they weren't avail for in the 295's....the shop says they will be fine and perform well??? Will this size change affect anything? Will it be fine? Also my cars not the wider body?
Old May 7, 2013 | 06:14 AM
NJSPEEDER's Avatar
NJSPEEDER is infamous around these parts
Giving up 10mm won't make a massive difference unless you are a super driver and really looking to get every last possible drop of performance out of the car in a competitive format.
Also if you are looking for tires specifically for the track why not slap on a set of hoosier's?
-Tim
Old Jun 16, 2013 | 04:36 PM
monojohn's Avatar
monojohn is just really nicemonojohn is just really nicemonojohn is just really nicemonojohn is just really nice
You likely won't notice a difference.
Old Jun 22, 2013 | 07:15 AM
ckchan21401's Avatar
ckchan21401 is infamous around these parts
I think it will be fine..10mm isn't much. I also run into the same issue since the tires I want don't always match the stock sizes.
Old Oct 22, 2013 | 06:20 PM
BayArea911's Avatar
BayArea911 is infamous around these parts
What is the wheel width? It shouldn't be much of a difference in terms of feel because its in the rear. You may end up having to run slightly different pressures than you were before.
Old Mar 23, 2014 | 03:16 PM
jloehlein's Avatar
jloehlein is infamous around these parts
What's the wheel offset? You may also need to check clearance with the inner wheel well at the front under full droop. Just jack up the car, rotate the wheel and see if you can hear it rubbing.
Old Jun 1, 2015 | 01:30 PM
ushgeo's Avatar
ushgeo is infamous around these parts
The sizes you show will all be fine on 11" width wheels. No effect on the car, imperceptible effect on grip.
Jul 29, 2019 11:13 AM
horsepowerfarm
Sep 10, 2015 06:09 PM
Sales@RSW
Sep 3, 2015 09:34 AM
Sales@RSW
BMW //M
Aug 26, 2015 06:41 AM
The Oss
Aug 24, 2015 08:19 PM
