Tuning/Modifications
Sponsored by: Supersprint
KA - In Memory of my Mom (Vincee) and best friend Michael J. Maring
  #2311
Old 12-17-2006, 05:23 PM
cjv's Avatar
cjv
cjv is offline
Moderator
These rods have two oil holes on the wristpin side. The journals are 2.0 diameter designed for the NASCAR oval bearing.
  #2312
Old 12-17-2006, 05:47 PM
mt72's Avatar
mt72 is an unknown quantity at this point
wow this is some quality work & parts
What brand are our rods ? carrillo ....
Head work look very very well done
oil pump 8k .... speachless
wow +++ rep
  #2313
Old 12-17-2006, 06:55 PM
cjv's Avatar
cjv
cjv is offline
Moderator
wow +++ rep
The rods were made by Pauter. www.pauter.com
  #2314
Old 12-17-2006, 10:11 PM
cjv's Avatar
cjv
cjv is offline
Moderator
  #2315
Old 12-17-2006, 10:17 PM
JarodL's Avatar
JarodL is a glorious beacon of lightJarodL is a glorious beacon of lightJarodL is a glorious beacon of lightJarodL is a glorious beacon of lightJarodL is a glorious beacon of lightJarodL is a glorious beacon of light
Chad, I am going to have Darren ban you from posting pictures unless they are of parts being put TOGETHER! Glad to see progress finally being made.
  #2316
Old 12-17-2006, 10:33 PM
cjv's Avatar
cjv
cjv is offline
Moderator
Jarod,
The motors have been together, tested, apart, tested and apart. The final assembly will be in January.
Heck, Jarod, personel from PMS have come over to check out what we did to the cams and cranks.
  #2317
Old 12-19-2006, 06:11 PM
sharkster's Avatar
[quote=cjv]The case has been shuffle pinned to keep the crank from walking. Note the 962 three index oil pump. It has three pick ups (one picks the oil up off the heads). This pump costs over 8k today by itself.
oh hell yes... the one we normally use is the GT3-R one which is about 25/% or that but does have an additional pick up.. so call it two:0
  #2318
Old 12-19-2006, 06:12 PM
sharkster's Avatar
These rods have two oil holes on the wristpin side. The journals are 2.0 diameter designed for the NASCAR oval bearing.[/quote]
Are those pauter?? Or who's?
  #2319
Old 12-19-2006, 10:35 PM
cjv's Avatar
cjv
cjv is offline
Moderator
Yes, they are pauter.
These are not stock dimension rods. The journal size has been reduced for the NASCAR oval bearings. The wrist pin size has been changed and an extra oil hole has been added to the wrist pin bore.
  #2320
Old 12-20-2006, 06:13 PM
ZLP's Avatar
ZLP
ZLP is offline
ZLP has much to be proud ofZLP has much to be proud ofZLP has much to be proud ofZLP has much to be proud ofZLP has much to be proud ofZLP has much to be proud ofZLP has much to be proud ofZLP has much to be proud ofZLP has much to be proud ofZLP has much to be proud of
These are not stock dimension rods. The journal size has been reduced for the NASCAR oval bearings. The wrist pin size has been changed and an extra oil hole has been added to thewrist pin bore.
I was over at CCR dropping off some cranks and they had some Pauter's that were going to be used with the NASCAR bearings. They said it was the hot setup and good for a lot of RPM. Trick stuff!
  #2321
Old 12-20-2006, 11:50 PM
cjv's Avatar
cjv
cjv is offline
Moderator
ZPL,
They did the work for us on the GT3 RS crank (with the ovals) prior to having the stroker cranks manufacturered. The stroker crank was also made with the 2.0" journals for the NASCAR bearings. This crank will be used with the second motor assembly.
  #2322
Old 12-21-2006, 09:20 PM
sharkster's Avatar
I use CCR as well
  #2323
Old 01-01-2007, 01:45 PM
cjv's Avatar
cjv
cjv is offline
Moderator
Back on 11-7-06 I had posted on this thread a discovery we had made about how to get more out of your intercoolers. I had shared this information with sharkster, Todd Z, Todd K and Rob King.
Recently I was reviewing the EVOMS website and discovered this. It was under there 996tt intercoolers as an option.
SWAIN Coating
SKU:ICOKCSSWAIN
Swain Tech Coatings is the leader in engineered thermal coatings. In the early 1970’s ceramic engineer Dan Swain developed the first successful ceramic thermal barrier coating. Since then, Swain Tech has remained the coating industry leader by continually developing coatings that increase power and durability that simply would not be obtainable without Swain’s coatings. For our ClubSport intercooler kit, where you want to get heat out of a part instead of holding it in, the Swain Tech BBE coating is applied to help further pull heat out of intercooler which helps further increase efficiency and power. Swain’s testing shows a ~10-15% heat dispersion efficiency increase with the BBE coating applied over the same part without any coating. Though the primary purpose of the coating is to improve cooling, the coating also offers a durable semi-gloss black finish.
As I said back then, it wouldn't take long until the cat was out of the back. Got to hand it to EVOMS ...... no grass grows under their feet.
  #2324
Old 01-01-2007, 01:55 PM
dbf73's Avatar
dbf73 has a reputation beyond reputedbf73 has a reputation beyond reputedbf73 has a reputation beyond reputedbf73 has a reputation beyond reputedbf73 has a reputation beyond reputedbf73 has a reputation beyond reputedbf73 has a reputation beyond reputedbf73 has a reputation beyond reputedbf73 has a reputation beyond reputedbf73 has a reputation beyond reputedbf73 has a reputation beyond repute
Chad - would it be worthwhile doing this to stock intercoolers?
  #2325
Old 01-01-2007, 02:13 PM
cjv's Avatar
cjv
cjv is offline
Moderator
I don't believe they could. Aren't the stock end tanks plastic? Then again if the tanks could be removed they may be able to coat the cores only. I don't believe Swain advertises their intercooler coatings but you can call and inquire about being able to coat the stock cores only. www.swaintech.com
They have always been more than willing to spend the time to talk to me about many of the parts they coat as well as the benefits these coatings provide.
You have already rated this thread Rating: Thread Rating: 90 votes, 4.16 average.
Quick Reply: KA - In Memory of my Mom (Vincee) and best friend Michael J. Maring
