Tuning/Modifications
Who knows Carbon Fiber?
Old May 15, 2010 | 02:50 PM
KAZ911's Avatar
KAZ911 is infamous around these parts
Originally Posted by logic factory
wet sand the top layer off. wet sand until you reach the cf weave; you'll know when you do because the typical milky residue from wet sanding will become grey.
some clear spray paint might be able to penetrate the cracks too.
exposing most interior's to the sun's rays will result in whats imaged above. one can drive sparingly during high sun and spend copious time applying protective products to exposed surfaces or they can accept the risk and enjoy other elements of the car; perhaps lateral and longitudinal agility.
They're actually not that discolored, it looks a lot worse in the pics. My steering wheel is new and if it weren't for the peeling etc. you wouldn't be able to tell between the two. I think i'm just going to try to fix this, I don't really feel like spending thousands of dollars on carbon as the cost to benefit ratio just isn't there.
Old Jun 21, 2010 | 10:21 AM
LamboTT's Avatar
LamboTT has a spectacular aura aboutLamboTT has a spectacular aura about
Use a 2 part spray epoxy made by a company called select products for the pieces on the dash. It is an instant hold after 30 seconds and it worked great on mine. This is a industrial type of adhesive/epoxy used in the fiberglass/custom audio field. Most shops who make fiberglass boxes will have it.
DB-Design-Group
Group Buys
46
Nov 3, 2015 11:27 AM
Texas1
Sep 20, 2015 09:12 AM
markj
Sep 17, 2015 02:11 PM
sparks
Sep 8, 2015 03:03 PM
