Tuning/Modifications
DIY Headlight bulb replacement on Porsche 996
Old Oct 21, 2006 | 05:35 PM
DimNSlow's Avatar
DimNSlow has a spectacular aura aboutDimNSlow has a spectacular aura aboutDimNSlow has a spectacular aura about
So, after having my local dealer's service advisor walk me through the process, I figured out how to change the light bulb on my halogen headlights, I figure I want to share the wealth:
Tools Needed:
- 5mm "female" hex socket
- extension rod for socket
- socket wrench
- replacement light bulbs, mine was H7
Process:
The steps I took was:
1) unscrew the plastic tab that holds the carpet to the side in the trunk
2) unplug the rubber round plug
3) stick the 5mm wrench socket into it and slowly turn until you hear a snap
4) keep turning slowly, it will then start pushing the housing out part ways.
5) pull out the housing, and replace the bulb
6) reverse process to reinstall the housing back in the car
I believe the same process applies to Xenon headlights.
Old Dec 15, 2006 | 04:59 PM
IhuangerI's Avatar
IhuangerI has a spectacular aura aboutIhuangerI has a spectacular aura about
Thanks! been meaning to clear out the mini orange bulb that sits in my headlight but was too scared to mess around.
(back in the day with my honda, all you needed as a screwdriver lol)
Old Apr 30, 2008 | 08:17 PM
jameslan's Avatar
jameslan is infamous around these parts
Porsche 911 Headlamp Tool
Just To add to this post, The Tool you need to change the headlamp bulb is included in your tool kit (Next to your spare wheel).
Might be stating the obvious here, but thought I would anyway!
Old Apr 29, 2012 | 10:07 PM
spenat's Avatar
spenat is infamous around these parts
Hi hoping someone could chime in what bulbs they would recc. My passenger side low beam went out tonight and going to fix tomorrow.
thanks
Old Apr 29, 2012 | 10:53 PM
rrrruben's Avatar
rrrruben is infamous around these parts
Simple DIY. I used Sylvania SilverStar® - Headlight
Part # H7STBP. They work just fine. For the most part, use an H7 bulb. Good luck.
Old Dec 29, 2012 | 07:33 AM
GT3 AvZ's Avatar
GT3 AvZ is infamous around these parts
Thumbs up GT3 Bulb Replacment
Tools Needed:
- socket wrench
Process:
It does, to add to the above link, remember the 5mm wrench socket must be turned to the left...i.e, its a left hand thread, it took me all of 5 min to change the bulb, thanks
joseph_number1
Jul 19, 2018 05:45 PM
PelicanParts.com
996 Vendor Classifieds
Aug 20, 2015 02:41 PM
PelicanParts.com
996 Turbo Vendor Classifieds
Aug 20, 2015 02:40 PM
PelicanParts.com
GT3/GT2/GT Vendor Classifieds
Aug 20, 2015 02:37 PM
Lucid Moment
Aug 20, 2015 02:22 PM
