Wheels/Tires
315/25/19 is too narrow for my wheels.... help
Old Mar 11, 2008 | 09:19 PM
DNugget991GT3's Avatar
i would love to put on a 325 or a 335.....
do i have any options ?
i tried looking for a 325/25/19 , or a 335 25 19, and no luck
i took off one of my wheels today to touch up the bottom of the brake caliper, and i noticed the rear tires are stretched onto the rim... i dont like the way it looks, and im not sure how safe it is...
i want to go wider.... i have plently of fender clearance... i think my rim is a 12" rear or 12.5"
damon ? help ?
Old Mar 11, 2008 | 10:38 PM
Gcalo's Avatar
Gcalo is a jewel in the roughGcalo is a jewel in the roughGcalo is a jewel in the rough
damon ? help ?
Michelin Pilot Sport Cup 325/30-19. Will fit a 12" rim nicely. Conti has the same in the Sport Contact 2 Vmax but don't know anything about the Conti tires for performance.
This will tell you everything you need to know: http://www.miata.net/garage/tirecalc.html
Old Mar 11, 2008 | 10:58 PM
iLLM3's Avatar
How is your 315 stretched on 12" rim? Mine isn't?
Old Mar 11, 2008 | 11:11 PM
i dunno man
my michelin ps2 looked streched, and the toyo looks stretched.. if you look at the rim from the inside, you can see the edge of the barrel..
Old Mar 11, 2008 | 11:12 PM
maybe im wider than 12"
whatever the case may be... can i go wider ? i dont want to go to a 30 series profile... it would be too tall
Old Mar 11, 2008 | 11:17 PM
iLLM3's Avatar
Anything over 315 throws the diameters out of whack, from what I have read. No need to go wider, it's already WIDE as hell, and your awd!
Old Mar 12, 2008 | 10:19 AM
wasnt it pontiac that said wider is better
btw, if youre wide enough, why did your car get sideways on the west side with a tap of the gas :P
Old Mar 12, 2008 | 11:21 AM
Gcalo's Avatar
No that was John DeLorean!
Use the tire calculator. It will tell you exactly what you need to know!
Old Mar 12, 2008 | 11:27 AM
damon@tirerack's Avatar
Moderator
Remember, our website will tell you recommended rim rangese for any tire you want. EX PS2:
http://www.tirerack.com/tires/Sizes....ilot+Sport+PS2
damon@tirerack.com
877-522-8473 ext. 4643
574-287-2345 ext. 4643
Or use this link:
Old Mar 12, 2008 | 12:48 PM
DynamicMotoring's Avatar
DynamicMotoring is infamous around these parts
Steve, I always use that size tire on Porsches with a 19x12 wheel, as its the only thing that really works with the AWD. The tire is actually meant for a 11.5" wheel for proper fit, but can be stretched to a 12". There arent any real options, unless you go to RWD.
Old Mar 12, 2008 | 01:44 PM
ill prob be going to rwd this summer.. what are my options ?
i would love a 335 in the back of that thing...
Old Mar 12, 2008 | 04:24 PM
345/30/19 Ps2.
Old Mar 13, 2008 | 11:45 AM
is that not too tall ?
Old Mar 13, 2008 | 06:06 PM
Nobody makes a 335 width for a 19", so its pretty much the only option. And if you are RWD, it would be fine. The Enzo uses that size stock.
Old Mar 13, 2008 | 06:58 PM
hmm
good to know
thanks man !
