Wheels/Tires
Track tire help needed......
Old Feb 22, 2009 | 12:49 PM
riverflyer's Avatar
riverflyer has much to be proud ofriverflyer has much to be proud ofriverflyer has much to be proud ofriverflyer has much to be proud ofriverflyer has much to be proud ofriverflyer has much to be proud ofriverflyer has much to be proud ofriverflyer has much to be proud of
I am running a very nicely set up KW3 suspension set on my 03TT. I want to get a set of 18" track wheels w/o disturbing the suspension tune that is in place.
I am running the 235/35--315/25 set up in 19" presently.
Closest I could figure for 18" match would be 235/40 and 305/30 but finding the rear tires is not easy.
What are you other tt guys running in 18" tire sizes and does anyone have a good solution to my problem?
thanks, John
Old Feb 22, 2009 | 04:00 PM
David9962000's Avatar
David9962000 has a reputation beyond reputeDavid9962000 has a reputation beyond reputeDavid9962000 has a reputation beyond reputeDavid9962000 has a reputation beyond reputeDavid9962000 has a reputation beyond reputeDavid9962000 has a reputation beyond reputeDavid9962000 has a reputation beyond reputeDavid9962000 has a reputation beyond reputeDavid9962000 has a reputation beyond reputeDavid9962000 has a reputation beyond reputeDavid9962000 has a reputation beyond repute
Why don't you run the stock size, 225/40 18 & 295/30 18 on a Michelin Pilot Sport Cup?
Old Feb 22, 2009 | 04:53 PM
riverflyer's Avatar
I was thinking oem size would be off in diameter but its not bad at all. Maybe thats the solution. I am trying to mimic the setup that is dialed in suspension wise but the stock set up in only a couple of tenths off in radius and 1% off in cirucumference.
Would be nice to run a wider rear, but its a good option, thanks
Old Feb 22, 2009 | 06:37 PM
If you want to play with tire size try this: http://www.1010tires.com/tiresizecalculator.asp
But I think stock is best for awd, abs, psm...
Jul 29, 2019 11:13 AM
horsepowerfarm
Sep 10, 2015 06:09 PM
Sales@RSW
Sep 3, 2015 09:34 AM
Sales@RSW
BMW //M
Aug 26, 2015 06:41 AM
The Oss
Aug 24, 2015 08:19 PM
