Wheels/Tires
Tirerack Damon, I need advice please
Old Jul 14, 2010 | 08:05 PM
og risker's Avatar
og risker has much to be proud ofog risker has much to be proud ofog risker has much to be proud ofog risker has much to be proud ofog risker has much to be proud ofog risker has much to be proud ofog risker has much to be proud ofog risker has much to be proud ofog risker has much to be proud of
I have a 2009 Tacoma CrewCab Prerunner. Im looking @ new tires on Tirerack website.
Thinking of putting some 265-70-17 Dunlop Rover M/T Maxx traction tires on my stock 17 wheels. Stock tire is 265-65-17.
Will these tires fit my wheels? or do I need different wheels?
Also does "E" load tires make any difference?
thx
Old Jul 16, 2010 | 12:13 PM
Wheel Dynamics's Avatar
Wheel Dynamics has a reputation beyond reputeWheel Dynamics has a reputation beyond reputeWheel Dynamics has a reputation beyond reputeWheel Dynamics has a reputation beyond reputeWheel Dynamics has a reputation beyond reputeWheel Dynamics has a reputation beyond reputeWheel Dynamics has a reputation beyond reputeWheel Dynamics has a reputation beyond reputeWheel Dynamics has a reputation beyond reputeWheel Dynamics has a reputation beyond reputeWheel Dynamics has a reputation beyond repute
The 265/70/17 has an over all diameter of 31.6 and what you have now is 30.6 with the new tires your speedo will say you're doing 60-mph but in reality you'll be doing 58-mph. You'll loose on pick-up.
Yes, they will fit your rim but question is do you really want to do that?
Just figured you should know.....
-Eli
Old Jul 16, 2010 | 02:12 PM
damon@tirerack's Avatar
Moderator
thx
The tires are just a bit taller, but will fit the truck's stock wheel fine. Above info is correct on pickup. They are heavier also, which may affect braking, too.
The stock tire is a 4 ply standard load tire. "E" load tires are 10 ply and much much stiffer. Not recommended unless you are doing heavy hauling or pulling, or heavy offroading and need that extra construction. They will be awfully harsh otherwise.
Please call me if I can help.
damon@tirerack.com
877-522-8473 ext. 4643
574-287-2345 ext. 4643
Or use this link:
Old Jul 16, 2010 | 02:26 PM
og risker's Avatar
Thank you everybody for the info.
I plan to get a 3" lift as well.
I do some off-roading @ our ranch as well.
From searching online, I found that the tires with most agressive tread pattern are usually 70 series...not many choices in 65 series...
Old Jul 16, 2010 | 07:52 PM
Good Luck to you in your choices....
-Eli
away
Apr 27, 2016 03:53 AM
flewis763
Oct 4, 2015 04:14 PM
gjpearce
Sep 30, 2015 04:26 AM
NBoost
Detailing
Sep 29, 2015 10:06 PM
lgl314
Sep 28, 2015 04:17 PM
