Wheels/Tires
Dumb Question - What is ET?
Old Jul 19, 2010 | 09:18 AM
leftlane's Avatar
leftlane has a reputation beyond reputeleftlane has a reputation beyond reputeleftlane has a reputation beyond reputeleftlane has a reputation beyond reputeleftlane has a reputation beyond reputeleftlane has a reputation beyond reputeleftlane has a reputation beyond reputeleftlane has a reputation beyond reputeleftlane has a reputation beyond reputeleftlane has a reputation beyond reputeleftlane has a reputation beyond repute
Any help without laughing would be appreciated - what exactly is ET in wheels? I think I understand that it is the offset that dictates how far out the wheel sticks from the hub, but I certainly don't understand how it is calculated or how to figure if one wheel or another would fit my car and my current tires (if that even matters). I have an 01 996TT - what is the stock offset, what can I use in aftermarket wheels, and how can I tell if I would need spacers (which I currently have)?
TIA!
Old Jul 19, 2010 | 09:34 AM
TheVenom's Avatar
TheVenom is infamous around these parts
short for einpresstiefe, in german means insert depth. we call it offset.
Old Jul 19, 2010 | 01:48 PM
Fastforwardwheels's Avatar
Fastforwardwheels is a splendid one to beholdFastforwardwheels is a splendid one to beholdFastforwardwheels is a splendid one to beholdFastforwardwheels is a splendid one to beholdFastforwardwheels is a splendid one to beholdFastforwardwheels is a splendid one to beholdFastforwardwheels is a splendid one to behold
Check Out http://wheeldynamics.com/Wheels.html
We carry a lot of different options for Porsche especially 996tt
Old Jul 23, 2010 | 04:28 PM
keeperofbeasts's Avatar
keeperofbeasts has a reputation beyond reputekeeperofbeasts has a reputation beyond reputekeeperofbeasts has a reputation beyond reputekeeperofbeasts has a reputation beyond reputekeeperofbeasts has a reputation beyond reputekeeperofbeasts has a reputation beyond reputekeeperofbeasts has a reputation beyond reputekeeperofbeasts has a reputation beyond reputekeeperofbeasts has a reputation beyond reputekeeperofbeasts has a reputation beyond reputekeeperofbeasts has a reputation beyond repute
Originally Posted by Jeff@pwp
What is it? It is the dimmension usually in mm that represents the distance from the true wheel width centerline (measured on the bead) to the hub mounting surface. (+) offset means the mounting surface is outboard of centerline and (-) offset means the mounting surface is inboard of the mounting surface.
The higher the (+) offset, the further a wheel will move inward on the vehicle. The lower the (+) offset the more the wheel moves outward from the vehicle. Of course as (-) offset increases the wheel moves outward on the vehicle.
Most, if not all, late model vehicles use (+) offset wheels.....
Cheers
excellent explanation, thanks! Can you also explain how spacers work...?
PV=nRT.
Sep 9, 2022 06:06 PM
takenotes996tt
Jan 20, 2016 06:34 AM
HotRod
Sep 10, 2015 07:17 PM
pjb84
Sep 2, 2015 12:57 AM
