Wheels/Tires
3 Piece Wheel Maintenance & Leak Detection
Old Aug 17, 2011 | 11:55 AM
COR Forged's Avatar
COR Forged is a glorious beacon of lightCOR Forged is a glorious beacon of lightCOR Forged is a glorious beacon of lightCOR Forged is a glorious beacon of lightCOR Forged is a glorious beacon of lightCOR Forged is a glorious beacon of light
Maintenance
In every day street use, three-piece wheels will provide years of service and require no special maintenance other than standard tire care and valve core replacement at tire change intervals. If you use your wheels for competitions and racing, it is recommended that both 1-piece and 3-piece modular wheels undergo inspection at the end of each season. For monobloc wheels, a thorough cleaning and visual inspection for any signs of stress cracks or fatigue as well as runout checks would be sufficient. If the wheels have undergone any type of impact damage and remained intact, it is strongly recommended that they are x-ray tested or have their finish stripped and undergo a dye penetrant test. The former is the most preferred, but if your preparation for a new season involves refinishing the wheels, the latter may be more practical since the finish will be removed anyway.
Three piece modular wheels require the same periodic maintenance as described above for monobloc wheels. Additionally, since racing involves frequent tire mounting and dismounting, it is also advisable to disassemble, thoroughly inspect, clean, re-seal, and re-torque each wheel.
            Leak Detection
            In the event you come across an issue where you’re losing air, below are some methods to further test where the leak is coming from.
                    The most popular cause for leaking wheels:
                        Assembled wheel with cured silicone:
                        Assembled wheel with stainless hardware & 90 degree valve stem:
                        Have Questions? Call Our Forged Wheels Experts 305-477-5850
                        Armytrix_F1_Exhaust
                        Jul 7, 2019 11:31 PM
                        gulf gt
                        Aug 27, 2015 10:27 AM
                        su_maverick
                        Aug 21, 2015 07:14 PM
                        Aug 21, 2015 09:56 AM
                        albert@velosdesignwerks
                        BMW //M
                        Aug 20, 2015 07:12 AM
