Wheels/Tires
Tire Pressure Monitor
Old Dec 23, 2015 | 12:29 PM
Raider89's Avatar
Raider89 is infamous around these parts
OK, dumb question for all. I recently purchased spare set of wheels and intend to mount new tires for track use only. I am trying to determine if I must have TPMs on the wheels during mounting versus just valve stems.
If this requires computer reprogramming from dealership, then will be pain in butt to move tires back and forth. What is the deal? Also, any recommendations for TPM and how long should they operate satisfactorily?
Thanks,
Old Dec 23, 2015 | 12:34 PM
damon@tirerack's Avatar
Moderator
TPMS sensors are not required to have in the wheels. A good metal valve stem should suffice if you don't mind losing the functionality of the system. Some don't like the sensors in race wheels. Once you put your stock wheels back on the system should see your new sensors and act normally.
damon@tirerack.com
877-522-8473 ext. 4643
574-287-2345 ext. 4643
Or use this link:
Old Dec 23, 2015 | 01:29 PM
Raider89's Avatar
On different question: are these Porsche tires supposed to be spin balanced or road force balanced (with simulated load)? what does dealership do?
Old Dec 23, 2015 | 01:41 PM
Moderator
We recommend road force balancing. It's the best balance and will usually find an out of round tire should you have one. Most dealerships use road force for their balancing.
damon@tirerack.com
Or use this link:
Old Jan 8, 2016 | 10:32 AM
Raider89's Avatar
I thought so, but seems unnecessary if buying quality tires. All the N* rated tires for Porsche, such as Michelin PSC2, better be perfectly round from factory for $500+ per tire. This would make spin balancing only just fine assuming tire mounted correctly aligning dots.
hksnlper
Lamborghini
Nov 26, 2015 03:21 PM
Ekaplan1020
Nov 10, 2015 06:42 PM
WheelB
Other British Cars
Nov 10, 2015 11:57 AM
REKX
Nov 9, 2015 09:00 PM
WheelB
Nov 4, 2015 08:47 AM
