attn:damon@tirerack
attn:damon@tirerack
just bought a 2006 lexus ls430 they stressed to me due to the tire pressure sensors in the wheels there is no way( yeah right) i can put aftermarket wheels and the sensors back on without voiding my warranty. is this true? if not what are my options. im feeling the oz wheels in 20inch.
Not sure on the warranty thread elsewhere, but I have never run into a mfgr. refusing to honor a warranty claim as a result of aftermarket wheels. Unless, of course the wheels are offset so wrong for the car that they are overstressing drivetrain components (ie lowrider wheels). As long as the wheels is designed to accept the OE sensor, the end result to the system is no different than before it was done.
It sounds to me like they were just trying to scare you into leaving the stock setup alone.
damon@tirerack.com
877-522-8473 ext. 4643
574-287-2345 ext. 4643
Or use this link:
damon@tirerack.com
Or use this link:
They can't deny your entire warranty for modifying something. They have to prove the modification caused the failure. If you chip your car and yor engine blows, you'll be screwed because you won't be able to disprove that the chip didnt cause the failure. However if you lower you car and your engine blows due to an internal malfunction they cannot deny you warranty service.
So if you get wheels and the tire pressure sensor breaks you can forget about having them fix that but who cares... all other things will be fixed.
away
04-27-2016 03:53 AM
alpha motoring
09-12-2015 10:53 AM
