Wheels/Tires
Tape-on weights on wheels
Old May 25, 2006 | 07:31 PM
djantlive's Avatar
Do tire shops remove old tape on weights when installing new tires? Or, do they just add more weight each time new tires are put on? How can the old weights be removed safely?
Old May 25, 2006 | 09:26 PM
MexicoBlue's Avatar
MexicoBlue Is a GOD !MexicoBlue Is a GOD !MexicoBlue Is a GOD !MexicoBlue Is a GOD !MexicoBlue Is a GOD !MexicoBlue Is a GOD !MexicoBlue Is a GOD !MexicoBlue Is a GOD !MexicoBlue Is a GOD !MexicoBlue Is a GOD !MexicoBlue Is a GOD !
They remove them. At least any decent installer does. No idea how hard or easy it is< or what magic potion is required though . . .
Old May 30, 2006 | 01:06 PM
rijowysock's Avatar
rijowysock is infamous around these parts
they remove, using a white plastic tool looks like a putty knife.. doesnt scratch rim and removes weight then solvent is used to remove sticky
btw your wheels should have VERY few weights if done properly.. most shops run it over and over adding and adding weights.. if done properly u can cancel out most the weights and barely run any.
btw i have a hunter mounting and balancing machine..because ima wheel *****.
Old Jun 24, 2006 | 12:48 PM
Wheel Dynamics's Avatar
Wheel Dynamics has a reputation beyond reputeWheel Dynamics has a reputation beyond reputeWheel Dynamics has a reputation beyond reputeWheel Dynamics has a reputation beyond reputeWheel Dynamics has a reputation beyond reputeWheel Dynamics has a reputation beyond reputeWheel Dynamics has a reputation beyond reputeWheel Dynamics has a reputation beyond reputeWheel Dynamics has a reputation beyond reputeWheel Dynamics has a reputation beyond reputeWheel Dynamics has a reputation beyond repute
Not very many shops will go throught the hassel of removing "all" of the glue.
Most will just remove and re-apply the new ones.....
-Eli
Jul 29, 2019 11:13 AM
RS GT3 RS
Sep 24, 2015 09:27 PM
The Oss
Aug 24, 2015 08:19 PM
Zero911
Aug 24, 2015 06:51 PM
pwdrhound
Aug 23, 2015 07:36 PM
