Which 2 bolts to drop TT Engine?
The two bolts are on the far side on each side of the motor. They are fairly big and hard to miss. You can lower those down with the jack under the motor, then slowly lower the jack down and the motor should come down a few inches.
They are on the underside of the car. It's hard to describe, but they are on the outside of the motor. Like they are far apart from each other, wider than the motor.
Easy to find and easy procedure to lower. Great way to access the top of your engine! Thanks for this thread...it helped me GREATLY.
Just take the nuts off(or just loose depending on how far you need to drop the engine), and lower away very carefully...
justin
Nervous.........
I know this is a couple months old, forgive me
I am getting ready to lower the engine to make easier work of the DV replacement... I'm nervous I'm going to ruin my car. Please, help squash my fears!!! I will put the rear up on jack stands, put my floor jack under the engine block, undo the 2 retaining bolts and then slowly lower the jack... It won't go too far, right? My engine isn't going to plop onto my garage floor or come out of alignment, right? Sorry for the stupid questions, just the thought of lowering the engine is kind of trippy
Also, when I do put it back up, what is the correct torque to tighten the retaining bolts back to?
Thanks guys!
Thanks guys!
1. No it won't fall on your floor. There is alot more to unbolt for that to happen.
2. Remove your airbox. (You have to remove this to get to the DVs)
3. Disconnect boost hoses. (They clip in/out and watch out for the O ring)
4. Don't disconnect the coolant hose (right side-coolant smells like death warmed over)
There is a failsafe built into this-look at the pulley guard-the engine will rest the guard against the back of the car so you only get 3-4 inches of movement.
Try reading my #6 post again or call me for a comforting speech
Rolf
Rolf
