LOG's and IAT's with Joe Toth Intake Scoops & Wagner 3.5" IC's PLUS Wagner 5.7" IC's
Back to Back Logs attached 2000 - 7000 rpm Protomotive Mafless 16g Tune
PLUS I have Wagner's new 5.7" Coolers that come with Carbon shrouds top and bottom, I will be fitting this week. The results should be interesting.
looking forward to everyone's input.
I would start in 2nd gear at 2500rpms and go wot as high as posssible, end of 4th at least, but end of 5th or even 6th would be better. Also take reference for ambient, boost etc and see how the temps got down after wot.
With my 4.5ICs I saw like 15-20C above ambient 2-3-4th gear at moderate boost, 1.3-1.4bar with big turbos, adding meth got me 5C bellow ambient
Hard to examine on a portable device but it looks like a couple degrees difference? I too would be interested in pulls in higher gears where things heat up more under load. Any pictures of the carbon ducting? Really interested in how that looks! How much do those cores weigh? Never seen that setup before, who sells it? Knowing ambient temp and speeds would help judge the logs but it looks like the scoops work, awesome!
Should be these Bad Boys?
http://www.wagner-tuningshop.de/#pro...0001078-1.html
Excited to see the results also!
