Torque Wrench recommendation pls: digital or analog? Which one is "best"?
I am getting deeper into my DIY mode and now am thinking about lubricating the rear GMG sway bar of my car. The D clamp is supposed to be tightened with a torque wrench, AFAIK 17 ft. lbs.
So does a simple analog model like this one from Sears work?
http://www.sears.com/craftsman-torqu...p-00944978000P
Then there is a better analog model:
http://www.sears.com/shc/s/p_10153_1...4593000P?mv=rr
And also digital model:
http://www.sears.com/shc/s/p_10153_1...4597000P?mv=rr
Any input appreciated. I am a complete amateur and don't do any major work on the car at all. The only time I go under is to adjust the sway bar.
TQ wrenches, DIY, can't believe what I'm reading.
Seriously, craftsman makes a nice analog that goes 5-100 ft lbs.
You'll find DIY projects very gratifying. You'll kick yourself for spending all that cash at tuners, 50% of the stuff is easily DIY.
Next thing you'll actually take that sled to the track
enjoy
enjoy
I've used the same for years, probably getting close to 10 now, always worked great. Just don't leave it set to your last torque #, always set it back to zero to keep the calibration and don't drop it or hit it.
But like I said above Can says he needs 17ft/lbs and this wrench starts a 25 so you'll need a smaller one for that job.
17ft/lbs is 204 inch/lbs so you could get a torque wrench that does 200 inch/lbs and it would be about 16.75ft/lbs.
This one is often times on sale or has a coupon available for $9.99-$14.99:
http://www.harborfreight.com/1-4-qua...ench-2696.html
Or you can rent it for free from Autozone for a $50 retainer.
Thanks everyone for the helpful replies. Sears number 2 it will be.
Chris, as I told Bob a while ago, my DIY days are not going to last long. My neck, shoulder, *and* elbow hurt for a couple of weeks after the last drop link change (was just trying different ones to see the difference). Partly because of my inexperience, partly because I don't have a real high lift and was crawling under working like Michelangelo. Difference is he painted whereas I was pulling apart !@#$%! rusty metals.
Hi Jenner, thanks I did notice that. But, the specs for the Sears microtork are in. lbs., not ft. lbs.:
http://www.sears.com/shc/s/p_10153_1...00100600&aff=Y
Craftsman Microtork® Torque Wrench, 25-250 in. lbs., 3/8 in. Drive
In other words, my 17 ft. lbs. requirement = 204 in. lbs. should be ok, I think? This is for the D clamps on the rear sway bar of our Turbo.
"The Best"? Depends what you are going to use it for. I'm strengthening my motor so I picked up one of these beauties. CDI torque-angle wrench. Torque calibration is not off more than 0.6%!
Eastwood now sells a digital torque wrench w/a torque angle meter which looks very close to the one posted by TTdude, it also looks like the one I use from Snap on.
http://www.eastwood.com/eastwood-torque-wrenches
Many to choose from
Mititoyo (MTI)
Sturdavent Richmond
Proto (very good for the money)
Mountz
CDI
Belknap
Blackhawk (Value Proto brand)
Utica (Division of Cooper Tools)
Armstrong Hand Tools (also a div of Cooper)
JH Williams
SK
I would go with Proto or CDI although all the above are good. Stay away from the "truck" people as they are WAY overpriced and its NOT a matter of "you get what you pay for - they live and die by financing to their customers). Sears sells whomever builds to their specs (lowest price gets it). Proto is lifetime as is CDI but as all should be calibrated once or twice per year depending on how often you use it. I would go digital as you can switch from metric to fractional by the push of a button.
Sturdavent Richmond
Mountz
CDI
Belknap
JH Williams
SK
Mititoyo (MTI)
Sturdavent Richmond
Mountz
Sturdavent Richmond
Mountz
Proto: http://www.amazon.com/SEPTLS5776006C-Pound-Ratchet-Torque-Wrenches/dp/B000OEXA22/ref=wl_it_dp_o_npd?ie=UTF8&coliid=IGPZYAF4457RS&co lid=1VGQTI9XJGIYD
CDI: http://www.amazon.com/Snap-Industrial-Torque-1002MFRMH-100-Foot/dp/B002LA19P2/ref=wl_it_dp_o_npd?ie=UTF8&coliid=I450T55A1HKYN&co lid=1VGQTI9XJGIYD
