Fluid Leak
Fluid Leak
I have noticed a red/orange tinged fluid leak, several cc's, adjacent to the passenger front tire. The fluid is in front of the tire, appears from the wheel well and only leaks a few cc's upon parking the vehicle after my daily Saturday drive. Any ideas on what it is or on the cause ?
Just pulled mine off the lift today. Whilst checking radiators for debris and vacuuming out as many leaves as possible I found many significant rock strikes. This could also be a source of your leak if big enough. As others posted, checking coolant lines in that area is a good idea. A few connections are accessible without removing bodywork. Please post pictures and results if you DIY your issue?
Can you take photos of your efforts and post up your results?
Look forward to seeing where your leak is coming from and how you went about the repair.
Here's the update, both side radiators are damaged because of all the rotten leaves, cigarettes and junk
Can't believe such expensive cars were not built with better bumper protection!
Thanks for your advice, I juste placed my order, I'm in Canada so 443$ each, still way cheaper than OEM from my Porsche dealer!
I am still waiting for my new radiators, should receive them next week. I will take pictures of the process. One thing for sure is you should look at yours to see if everything is fine, removing the bumper takes only 15 minutes.
