TheRock's 997.1 TT to GT2RS / 997.2 Intercooler DIY Guide
OK Guys,
I was able to get my new intercoolers installed yesterday and thought I would document and help others as in the past.
Many of you have asked for this, so here it is. As always, I hope you find it helpful. If you have a better way to do it...Knock yourself out. I created this DIY and put in the time in the spirit of helping my fellow enthusiasts.
Good luck to you all. It is a pretty straightforward process, and I hope I documented and outlined it in a way that is easy to follow and logical!
Certainly, if you see opportunities to help others, or tips please post here for others.
Included in my DIY is a "Bonus" DIY on how to create and use a tester, to pressure test your IC's.
As in the past, I host these on my personal web server, so if it gets a lot of traffic, it may flake out....so just try again until it works.
LINK TO THEROCK'S 997 TURBO INTERCOOLER UPGRADE DIY
Enjoy, and let me know if it helps....
DC
PS: I also installed new Silicon Intake Ducts/Pipes and will create a DIY when I have time...If helpful....Pretty soon I will have enough DIY's to publish a CD and sell on eBay
DC
Nice job Rock, Your detail is always amazing to follow.
Just wondering, why did you decide to use zip ties?
Also, Since I cant really see from the photos, are you leaking air from the intake (upper part) of the ducts to ambient air?
Thanks....
Tabs are short with wider IC, and did not want to mangle the IC by bending edge lip, or air guides by cutting more off. Also seems very secure.
Not sure I understand? Air ducts still fit great...a little tighter, but foam rubber compresses. On the IC, it is tight too after trimming and using the gasket.
Thanks....
DC
Glad yours worked out...
DC
Well....Yes and no. I got it all back together and also pressure tested them and all is good. Took it out for a spin and it runs great! It was extremely cold out and since then has even been colder (-15 at night, and high of -5 days)....Oh, and a buttload of snow fell and the salt came out and then wind. So it is a mess and likely won't test again for a while.
So hard to tell any difference as I think the outside temps were ~20 degrees when I tested...so IAT's were very cool!
Did notice a nice difference with the Intake Ducts. It just seems to have 0 hesitation....and keeps accelerating...
Take care,
DC
The thread is somewhere here or on porscheboost.
DC
