FS: Mercedes Benz SL55 AMG (Modded - FF build)
Year: 2003
Make: Mercedes-Benz
Model: SL-Class
Price: $33000
Mileage: 67000
Color: Diamond Silver Metallic
Location (State): MD
Transmission: Automatic
Drivetrain: Rear Wheel Drive
The car has low miles (approx 7K per year since new) currently 67K miles but runs better than cars with much lower miles, all fluids serviced, dampers and ABC suspension in great shape, no SBC brake problems, Top works perfectly, new battery installed. Engine oil changed every 3.5K miles with Mobil 1 and BG MOA and 44K treatment applied at each oil change, all fluids synthetic, trans has been flushed properly, chassis bushings, control arms, joints, and sleeves properly lubricated at intervals. I am extremely meticulous and knowledgeable about the R230 cars, I've owned 2, an SL500 and this SL55 AMG.
I am 37 years old, a professional and a car enthusiast; I've owned several different cars from each German marquee at one point or another. I bought this car from it's orig. owner who only kept it for a few years before I purchased it on a trade in almost new at the time, I have an unlimited mileage Chrysler Service Contract (CSC) extended full coverage warranty through April 2014 which is 100% transferable to the new owner and comes with the car. This is the best warranty out there for the car and has already paid for itself – true bumper to bumper care no questions asked. The car is runs perfectly and you have the peace of mind of the best warranty out there for these cars which you can no longer get for AMG cars.
The car is clean inside and out, clear title, No accidents, full records and service history included and a folder with each and every receipt, work history, everything I am a meticulous record keeper. Car also comes with original owner’s manual and related material.
The car is unique - the ONLY complete Chris Jannasch of Floored Fab SL55 AMG full build, he had the car in his shop in Arizona to do the build. It was extensive, took a year, and he’s likely not to do another one, the following are some of what has been done to this car:
- True Long tube custom floored fab designed and fabricate headers by Chris... custom mid section x-pipe and full exhaust w/ test pipes and with 200 Cel cat pipes also if you need to bolt those on... this is all Jet hot coated inside and out
- custom intake including filter boxes runners and Y-pipe, custom aluminum sheet metal tig welded then coated, it's a 3 piece part crafted by Chris
- Custom 82mm Throttle body with CNC machined bored S/C sleeve
- ASP custom (and very rare) 185mm Pulley
- dual I/C pumps, Front mount Heat exchanger and trunk mounted Remote Reservoir separated cooling circuit for Supercharger...custom setup by Chris with the hand fabricated tank under the trunk divider for easy access, the cooling loop ensures that the charger is operating effectively without ever getting into heat soak
- quaffe LSD
- MBArt toe link kit
- MBArt custom Adjustable Camber arms
- High performance BMC air filters
- SDS ride height adjusted and properly set up with the toe links and camber arms
- OE tuning engine management performance tune, done by Jeremy and ties the entire build together, the car really benefits from this tremendously and Jeremy is the best out there as many know from the cars he has tuned and their performance.
- comes with dyno charts - 509.2 hp/ 589.6 lb-ft TQ on Jeremy's Dyno Dynamics tuning dyno in California which reads approx. 20% lower than dynojet (equivalent numbers are 611.04 hp/ 727.52 Tq) AT THE REAR WHEELS!!! I am more than happy to dyno the car again at a dyno of the potential buyer’s choice with the potential buyer before purchase to verify the power the car is making, no problem.
- all new injectors done during the build
- High performance spark plugs per Chris' spec in the car as well.
- custom Single slat grille
Asking $33,000 USD for the car as it comes with factory wheels and tires.
You can also choose to get the new/never used CCW drag pack 16" rear with MT Street Drag Radials also available for additional cost ($1500) for Wheels and tires.
I consider this car to be the ultimate SL55 AMG, it looks factory on the inside and outside, but built with no expense spared (over $25K invested including all parts, hardware, extras, and services), I really put a lot into this car!
As for performance the car stock it did a 12.03 @115 mph on street tires (my sig below) that's before it went to Chris at Floored Fab! Chris built this car to run 10.xx and have the drivability of a daily driver, those two main goals were our objective in this build. I personally believe this car has that potential and think we’ve reached our goal. Last year we were going to get the car on the track but wanted to get the rear camber arms and toe links done and those took some time to make, by the time the car was ready toward the end of the year I couldn’t make it to the two track days due to work. The car was supposed to be run this year but since I picked up a new car in January it’s for sale I decided to be safe and park it in the garage on a trickle charger.
Several members can vouch for this car and this build, Some of them are Chiromikey and Alan (one of the fastest if not the fastest E55 around), Benz-O-Rama (Clayton), Ahmad (Blackbenz), Jay (Absolutelydriven), guys over at ACGSD, Charlie, Chris of Floored Fabrications, Jeremy of OE Tuning, and more. A lot of these guys helped along the way.
I'm only selling because I just purchased another car and need to make room in the garage, otherwise I would keep this car for sure. Please contact me for price options, details, and more pictures. sunirghosal@hotmail.com or (202) 641 - 8211
Thank you very much for taking a look at my ad and I look forward to your inquiries, comments, questions, and finding the right owner who will appreciate this car, and all that I have had done and cherish her like I have. Serious inquiries only.
Here is a full set of pictures:
http://www.flickr.com/photos/chriswalshphotography/sets/72157628975715661
Here are some teasers
Good luck with the sale bud!
A small addition to Sunir's very thorough description of the car if I may... This thing sounds AMAZING!
Friday bump folks...man lots of views but not much interest. The price is negotiable guys, just looking for serious potential buyers. Please contact me if you're interested, make an offer, the worst that will happen is we can negotiate a bit or I'll say no, and even if that's the case there can be room to work out a deal where we both walk away happy
Thanks for the kind words guys I hope the potential buyers will appreciate this car as much as I have and value what Ive done to her... I am open to working on price to come up with what works for the new owner, as long as we both walk away feeling like the deal was right!
I am relocating to the states and have been looking for an alternative to a 996tt. Not trying to lowball, what is the bottom line? Cash is tight with the relocation, had planned to bring my car, red tape to import makes this a no win situation. Please let me know your bottom line. Will appreciate your dedication to the build. cash is tight, and i want the right car.
I suggest we take this to email...give me an email for more details on price etc ... sunirghosal@hotmail.com
I look forward to hearing from you and again, thank you
