iPhone bluetooth sync problem
Old Jun 3, 2009 | 12:52 AM
pk8's Avatar
pk8
pk8 is infamous around these parts
Hi,
Has anyone else had problems syncing an iPhone with PCM via bluetooth? Dealer spent an hour trying to get it to work to no avail on a new 09 GTS. I got the iPhone to pair to PCM but then it doesn't show up on the device list.
Thanks.
Old Jun 3, 2009 | 01:05 AM
Prince's Avatar
Prince is infamous around these parts
Hey PK8 ,
Last night my I Phone was working with PCM via Bluetooth.
1) Turn on your iPhone Bleutooth
2) Go to Seetings
3) General
4) Bluetooth
5) Devices .. you shoud see a meesage on your PCM screen than from your iPhone will ask you to enter 4 digts to sync with PCM .. than it will work :O) .. Plus address book can be seen on your PCM screen
Cheers
Old Jun 3, 2009 | 09:23 AM
rada70's Avatar
rada70 is infamous around these parts
What I did on mine, I had to turn the Bluetooth in the IPhone off while pairing then turn it back on.
Old Jun 7, 2009 | 09:43 PM
pk8's Avatar
pk8
Thanks. The iPhone (and my blackberry for that matter) both actually pair with PCM (3.0) and the PCM says "successfully registered" but then, for some reason, the phones don't show up in the list of devices nor does it work... Maybe they can downgrade the car to PCM 2.0...
PK8
Old Jun 8, 2009 | 08:58 AM
jyupitt1's Avatar
jyupitt1 has a reputation beyond reputejyupitt1 has a reputation beyond reputejyupitt1 has a reputation beyond reputejyupitt1 has a reputation beyond reputejyupitt1 has a reputation beyond reputejyupitt1 has a reputation beyond reputejyupitt1 has a reputation beyond reputejyupitt1 has a reputation beyond reputejyupitt1 has a reputation beyond reputejyupitt1 has a reputation beyond reputejyupitt1 has a reputation beyond repute
The PCM 3.0 on my 2009 cs syncs with my gf's iphone flawlessly. With my verizon blackberry 8830 however, was not as smooth. The first time it did synch with no issues. Then I had a replacement 8830 a week later and the PCM would not communicate with it. I disconnected the device, restarted, deleted the device and it was no help. I was about to post on the forum for help and call my dealer. Luckily last night i had some free time. After about 15 mins of playing around with every option turned on and off, rebooting the phone and turning BT on and off on the car, it finally worked.
My experience with BlueTooth is that the initial handshake can be shaky, it applies to not just phones but headsets, keyboard/mouse etc. Once connected, it works well. Just be patient, and keep trying. You will get it to work eventually.
Old Jan 30, 2021 | 10:57 PM
WilhelmK's Avatar
WilhelmK is infamous around these parts
iPhone Bluetooth sync problem
Hi all,
I have a 2009 Cayenne S and I’d like to stream music from my iPhone to the PCS through Bluetooth.
I’ve read a lot of threads, and it sounds like the PCS 3.0 doesn’t have the A2DP protocol.
My car also does not have an Aux or USB connector in the console.
I’ve seen people post about a Porsche to 30 pin iPod connector— does the PCS have a place inside that I could connect this cord to?
Old Feb 5, 2021 | 07:24 AM
David.Peters's Avatar
David.Peters is infamous around these parts
https://www.suncoastparts.com/product/SKU955FAIK.html
you then use a usb A2DP in aux or 30pin iPod to lightning converter
scatkins
Nov 26, 2017 07:37 PM
M_coupe1999
Apr 25, 2014 09:12 PM
TooSixy
Dec 29, 2010 07:11 PM
trice9
Nov 5, 2010 02:00 PM
997CarreraS
Jul 2, 2010 02:31 AM
