PCM display
Are you talking about customizing that screen? Because there are right and left arrows on screen showing you have 3 other information displays available.
If you are indeed talking about just that screen, no. The only user-customizable screen I'm aware of is not on the main PCM display, but rather on the multi-function display next to the tach. If you are looking at the general car info screen there, you can customize what each line displays. I have mine set to lateral and forward G's, 12 volt battery status, and compass.
It does. If you didn't have a g-force meter, you wouldn't have the top two lines of the display: acceleration long and acceleration lateral. Though mine doesn't look like that, exactly, since I have a 2015. If it's like mine, one of the possible displays for the multi-function display next to the tach is a radar-like display that shows both at once.
Try scrolling through the displays. Also check in the settings if that screen is enabled. I have a couple of screens turned off myself because I don't care about them.
pwdrhound
11
11-25-2015 01:18 AM
