Filters on turbos
Ok bonus question can I pass emissions test with MAF delete?
Goal for mods = Power Efficiency. I have a TTS and my opinion is that it makes nice power in stock form. The physicist in me is more interested in eliminating inefficient designs made necessary by mass production and/or regulations e.g. intake/exhaust restrictions and ECU tuning.
It was cool for a couple of days and then it got old quickly. It made the car sound like a Japanese tuner car. I didn't feel any huge performance gains / differences either.
Just my opinion and FYI. I tried this on my TT for a while. You should be aware that you will hear A LOT MORE turbo whine and air swooshing sounds with filters directly on the turbos.
also lot of guy like the turbo noise.
what this on stock turbos? It makes a huge performance difference when upgrading turbos. Here is a pick of the stock tubing size vs a small k16 billet wheel. Tubing is much smaller than the wheel. This restriction makes turbos spool slower and make less peak hp.
I have since added a bunch more mods since: Injectors, larger IPD plenum, larger TB, Intercoolers, larger flexible (Markski) intake hoses.
I might try the direct filters on the turbos again just for fun to see what it is like with all the mods I now have. Regardless, the change in intake sounds makes it not worth it to me regardless of the gains...It was that annoying to me. Again just my opinion. The good thing is that it is really easy to do especially if you already have Mafless and Markski's flex intake hoses. I simply bolted a K&N filter directly to each turbo and temporarily disconnected the Markski flex intake hoses.
It was not on stock turbos. At the time It was on upgraded K16 billets & Kline HiFlow 3" X exhaust, COBB AP tune, all from Sam at "By Design" (Sam is great).
Agreed. I already had the 2.5" intake piping so the difference was negligible.
The issue I have with that is losing the top duct! I think the ducting is important even if it's a draw through system. There's enough room to run pipes and keep the duct, I intend to seal my fenderwell with some neoprene where the tubing passes through to try and reduce grime kicked up as even up there dirt finds a way!
