SLK 55 AMG Black Series
Old Jul 22, 2006 | 02:11 PM
turbo187's Avatar
turbo187 Is a GOD !turbo187 Is a GOD !turbo187 Is a GOD !turbo187 Is a GOD !turbo187 Is a GOD !turbo187 Is a GOD !turbo187 Is a GOD !turbo187 Is a GOD !turbo187 Is a GOD !turbo187 Is a GOD !turbo187 Is a GOD !
SLK 55 AMG Black Series first from AMG Performance Studio
The opening of the AMG Performance Studio is being marked by the introduction of its first model, the SLK 55 AMG Black Series. You may recall the Black Series is one of three series being produced by the Performance Studio, the other being the high-end, track ready Signature Series and the Edition lineup featuring mostly cosmetic changes to AMG production models.
The SLK 55 AMG Black Series is a special coupe version of the V8 AMG roadster with a carbon fiber roof and AMG's 5.5-liter V8 producing 400 horsepower and 383 ft-lbs. of torque. Other special items include 19-inch AMG forged wheels that offer a 68 lb. weight savings versus the standard car's 18-inch alloys, an AMG adjustable sports suspension and composite brakes with six-piston calipers up front. The coupe also gets a redesigned front apron, nice looking carbon fiber side air vents and wider front wings. All told, the extensive use of carbon fiber, the absence of the standard car's retractable hardtop and the lighter wheels lead to a total net weight savings of around 100 lbs. The interior also gets swathed in carbon fiber trim, although more for visual impact than function.
Only 100 SLK 55 AMG Black Series will be produced by AMG at a cost of €107,300. Delivery has already started, so if you didn't get one yet, you're likely out of luck.
SLK 55 AMG Black Series: The perfect mix of performance, handling and lightweight design
* AMG 5.5-litre V8 engine with 294 kW/400 hp and 520 Nm of torque
* Weight reduction through lightweight components and non-retractable carbon-fibre roof
* 19-inch forged AMG wheels and adjustable AMG sports suspension
Stuttgart, Jul 21, 2006
As the only eight-cylinder roadster in its segment, the Mercedes-Benz SLK 55 AMG delivers an exceptional driving experience. Now the two-seater is becoming even sportier: Mercedes AMG has developed an exclusive, emphatically puristic special series as a coupé variant, a car that sets new standards in handling dynamics - the SLK 55 AMG Black Series. With the AMG 5.5-litre V8 engine, which has been boosted to 294 kW/400 hp and 520 Nm, the numerous lightweight components, the non-retractable carbon-fibre roof, 19-inch AMG forged wheels, AMG adjustable sports suspension and AMG high-performance composite brakes, the special SLK 55 AMG brings its sports car talents to bear even more convincingly - and cuts an impressive figure especially on racing circuits.
Broad, brawny and low-slung - it's clear at first glance that the SLK 55 AMG Black Series is something very special. It offers a captivating view from the front with a redesigned AMG front apron and its broad openings, which supply the added transmission-oil cooler and the high-performance steering-oil cooler with plenty of fresh air. In addition, new side outlets made of carbon ensure effective ventilation for the engine-oil coolers. The front wings, now wider, are made of reinforced plastic with ultra-light carbon-fibre composite material and feature black outlined air outlets. The non-retractable hardtop of the two-seater is also made of carbon-fibre composites, and the black central section with a visible carbon-fibre structure provides appealing visual effects. The elimination of the vario roof and the entire roof hydraulics not only makes possible a significantly lower centre of gravity but also leads to a notable reduction in weight: With a kerb weight of 1495 kilograms according to EC standards, the SLK 55 AMG Black Series is 45 kilograms lighter than the basic vehicle. That improves the weight/power ratio from 4.3 to 3.7 kg/hp.
Engineers not only optimised the weight but also gave the Black Series an optimised AMG 5.5-litre V8 engine with a maximum output of 294 kW/400 hp and 520 Nm of torque. A modified air intake, reduced-resistance AMG sports air filters, new high-performance headers and a new valve-timing scheme ensure a more efficient charge cycle and make the eight-cylinder unit even more responsive to accelerator pedal movements - which is also evident from the inimitable and even more impressive AMG V8 sound.
The combination of low vehicle weight and a powerful AMG eight-cylinder engine ensures first-class performance. This SLK 55 AMG accelerates from zero to 100 km/h in only 4.5 seconds (standard model: 4.9 s), and it takes just 15.5 seconds for the Black Series to reach 200 km/h (standard vehicle: 17.5 s). Power transmission is accomplished using the AMG SPEEDSHIFT 7G-TRONIC with manual drive program ("M") and AMG aluminium gearshift paddles on the steering wheel.
Overview of key data:
Cylinder arrangement/valves per cylinder: V8/3
Displacement cc: 5439
Bore/stroke mm: 97.0/92.0
Compression ratio: 11.0 : 1
Output: 400 hp at 5,750 rpm
Max. torque: 383 ft-lbs.
Combined fuel consumption: 12.2 l/100 km
Acceleration 0-62 mph: 4.5 secs
Top speed km/h: 175 electronically limited
AMG adjustable sports suspension, forged wheels and composite brakes
The suspension and the brake system are the ideal partners for the dynamic power package. The AMG adjustable sports suspension, optimised for the racetrack, allows impressive cornering speeds. In this chassis technology taken from motorsport, the compression and rebound stages of the front and rear-axle shock absorbers can be tuned harder or softer - making it possible to adjust the damping comfort and driving behaviour to one's individual purpose. The ride height can also be lowered or raised by five millimetres. The modified elastokinematics at the front axle and the specially tuned mounting of the major assemblies ensure more precise steering and stability when braking - which is particularly advantageous in the intense driving on racetracks. A brace in the engine compartment guarantees additional rigidity to cope with higher lateral forces.
The SLK 55 AMG Black Series has large, ultra-light, forged AMG aluminium wheels in the sizes 8.5 x 19 and 9.5 x 19. Compared to the 18-inch light-alloy wheels of the standard vehicle in widths of 7.5 and 8.5 inches, the full wheel assemblies, including tyres, weigh four kilograms less. The advantage is even clearer when compared with equally wide, multi-piece 19-inch AMG light-alloy wheels. In this case, the weight savings come to 31 kilograms. The weight reduction results in a greater responsiveness on the part of the speed-sensitive power steering - which is also equipped with a more powerful servo pump. The elegantly proportioned multi-spoke forged wheels fill the striking wheel housings perfectly and are fitted with tyres of sizes 235/35 ZR 19 (front) and 265/30 ZR 19 (rear). As an option, and at no extra cost, the customer can also choose special Pirelli sports tyres with a very high grip factor and outstanding wet-driving properties. Superb braking is ensured by the AMG high-performance brakes with large composite brake discs (360 x 32 millimetres) and six-piston fixed callipers at the front axle.
Interior with the functional atmosphere of a real racing car
The racing features are consistently carried over into the interior. Two specially developed AMG sports bucket seats without sidebags in black pearl velour and with a silver AMG logo provide the best possible lateral support; the new AMG ergonomic sports steering wheel in leather and Alcantara permits optimal vehicle control. An abundance of carbon fibre on the interior door linings and the trim elements, as well as the black roof lining, give the interior the functional atmosphere of a real racing car - and thereby affirm the almost 40-year motorsport history of Mercedes-AMG. The Black Series lettering on the carbon-fibre trim over the glove compartment and on the boot lid signals the special status of this powerful and puristic two-seater.
Despite handling dynamics suitable for the racetrack, the SLK 55 AMG Black Series, manufactured by hand in the Performance Studio, offers all the features that set a real Mercedes-Benz apart: fitness for everyday use, durability, safety and quality. The first models of the unlimited AMG special series will be delivered to customers beginning in July. The price in Germany is € 107,300 (incl. 16 % VAT).
Old Jul 22, 2006 | 02:14 PM
turbo187's Avatar
and some more photos...
Old Jul 22, 2006 | 06:31 PM
v35's Avatar
v35
v35 has a reputation beyond reputev35 has a reputation beyond reputev35 has a reputation beyond reputev35 has a reputation beyond reputev35 has a reputation beyond reputev35 has a reputation beyond reputev35 has a reputation beyond reputev35 has a reputation beyond reputev35 has a reputation beyond reputev35 has a reputation beyond reputev35 has a reputation beyond repute
beautiful ride.
Old Jul 22, 2006 | 06:47 PM
MeanMachine's Avatar
Love it wished mine had 400 it has 360hp
Old Jul 22, 2006 | 08:12 PM
TKDalumni's Avatar
TKDalumni is just really niceTKDalumni is just really niceTKDalumni is just really niceTKDalumni is just really nice
Looks cool...
Old Jul 23, 2006 | 04:37 PM
pilone's Avatar
pilone is just really nicepilone is just really nicepilone is just really nicepilone is just really nicepilone is just really nice
That's an agrressive looking MB!!!!
In my opinion that new special edition added lots of points to the SLK 55...now looks like it should have been!
400hp are really loads on a car small like this one and the CF roof contributes to have a better handling..so cool!
Thanks for the info turbo187
Old Jul 23, 2006 | 04:44 PM
blackbenzz's Avatar
blackbenzz is a glorious beacon of lightblackbenzz is a glorious beacon of lightblackbenzz is a glorious beacon of lightblackbenzz is a glorious beacon of lightblackbenzz is a glorious beacon of lightblackbenzz is a glorious beacon of light
Looks good. Worth the extra money? No!
Old Jul 23, 2006 | 05:59 PM
turbo187's Avatar
No problem Pilone! I think that they fixed some of the things that were wrong IMO with the slk, but i still wouldn't buy it for that much money... I'd rather have a fully optioned 997tt!
Old Jul 24, 2006 | 03:24 PM
pilone's Avatar
These are words my friend!!
You just got 1000 style points...
We are on the same way!
Great...
Armytrix_F1_Exhaust
Jul 7, 2019 11:31 PM
osj911
Aug 26, 2015 06:41 PM
