FS: Twin Turbo Z06 ((PICS))
2001 Corvette Z06
Black
Mod red interior
22,xxx miles on the car
600rwhp/620rwtq at 10psi (.7bar) on pump 93 octane gas. Motor/Turbos are EASILY capable of 15psi and +/-950rwhp
engine:
MTI built forged LS6 9:0 compression
MTI Stage IIR heads
MTI custom grind cam
LS1 Rollmaster Double roller Timing Chain
Ported/Polished Oil Pump
Custom Scavenger Pump for turbos
Moroso Catch Can
LS1 Slave Cylinder
Cometic Gaskets
ARP bolts/studs
2) GT30 55mm turbos in a T28 housing, T04B Compressor housing
FMIC
Ceramic Coated 321 Stainless Steel Tubular Manifolds
Tial 38mm Waste gates
HKS SSQV Blow Off Valves
Braided Oil Feed and Return
Water Feed and Return
K&N 2.5" Dual Outlet Filter
65lb Mototron injectors
Kenne Bell BAP
Walbro 255lph Fuel pump
Exedy Twin Disc clutch
interior:
AEM Wideband
Defi Boost guage
Blitz spec r DSBC boost controller
XM Radio
B&M Ripper Shifter
Exterior:
SLAMMED
Nitto 555r's up front
Nitto 555RII's in the rear- 305's
euro taillights
Brakes :
Brembo cross drilled/slotted Rotors (new in box uninstalled)
Green Pads
Turbo kit was made by Boostlogic (Austin, TX), Motor done by MTI (Houston, TX) and all other work done by Performance Motorsports (Austin, TX). No expense was spared in this build and the quality is top notch. The car runs/drives/idles/sounds stock until you lay into it. The only way anyone can tell this car isn’t stock is by the sounds of the turbos spooling and the BOV’s, beyond that the car appears and sounds stock.
contact kwebber@gmail.com for more info/questions
asking $40,000 obo
and now for the pics:
Black
Mod red interior
engine:
MTI Stage IIR heads
Moroso Catch Can
LS1 Slave Cylinder
Cometic Gaskets
ARP bolts/studs
FMIC
Kenne Bell BAP
interior:
AEM Wideband
Defi Boost guage
XM Radio
B&M Ripper Shifter
Exterior:
SLAMMED
euro taillights
Brakes :
Green Pads
asking $40,000 obo
Originally Posted by TurboTuner
Just curious, where are the turbos located? Whats keeping it from 900rwhp if its easily capable of it?
only thing holding this car back from big power is race gas and turning the boost up
Personally, I never had any intentions of using race gas, to me thats too much of a pain in the a**
That is a nice setup, I would run the race gas turn up the boost and advertise it with the 900rwhp+. That would get people's attention for sure! I've seen some bad twin turbo setups on C5s, thats the reason I asked where it was located. Some guys go as far as putting the turbos in the rear by the exhaust! Talk about lost of efficiency, but this setup is sweet! GL with the sale!
