Tech / How To
996 HID Conversion Kit - DIY
Old 02-19-2009, 09:54 PM
hobbes's Avatar
hobbes is a splendid one to beholdhobbes is a splendid one to beholdhobbes is a splendid one to beholdhobbes is a splendid one to beholdhobbes is a splendid one to beholdhobbes is a splendid one to behold
I recently bought a Super Slim HID conversion kit from ebay. I thought I would share what I did to make it happen. Easy job, so here it is.
Any questions, let me know.
HID_DIY.pdf
Ken
Old 02-24-2009, 11:03 AM
Steve's 996's Avatar
Steve's 996 has much to be proud ofSteve's 996 has much to be proud ofSteve's 996 has much to be proud ofSteve's 996 has much to be proud ofSteve's 996 has much to be proud ofSteve's 996 has much to be proud ofSteve's 996 has much to be proud ofSteve's 996 has much to be proud of
Ken, very nice write up. Thanks
Old 02-25-2009, 11:38 AM
Falken's Avatar
Falken is on a distinguished road
thanks alot...good write up, i'm going to be putting HID's into my viper so this will definetly come in handy as i'm sure the process will be somewhat similar.
Old 03-02-2009, 03:55 AM
xpsonic's Avatar
xpsonic is on a distinguished road
great tip.
Old 03-18-2009, 04:54 PM
Airborne Ranger's Avatar
Airborne Ranger is a splendid one to beholdAirborne Ranger is a splendid one to beholdAirborne Ranger is a splendid one to beholdAirborne Ranger is a splendid one to beholdAirborne Ranger is a splendid one to beholdAirborne Ranger is a splendid one to beholdAirborne Ranger is a splendid one to beholdAirborne Ranger is a splendid one to behold
Thank you, great write up man!
Old 05-25-2009, 12:43 PM
Ronny's Avatar
Ronny is on a distinguished road
Great righ tup, i used this to install my HID's worked perfectly. I've got a 2000 996 as well.
Old 05-25-2009, 05:12 PM
Ronny's Avatar
Does it matter which way the bulb goes in? Because my right headlight is much brighter than my left one.
Old 05-28-2009, 01:30 PM
SXN's Avatar
SXN
SXN is offline
SXN is a splendid one to beholdSXN is a splendid one to beholdSXN is a splendid one to beholdSXN is a splendid one to beholdSXN is a splendid one to beholdSXN is a splendid one to beholdSXN is a splendid one to behold
Very nice writeup.
Old 06-16-2009, 08:37 PM
adnanm3's Avatar
adnanm3 can only hope to improve
nice writeup
Old 02-26-2010, 04:35 PM
Shap's Avatar
Shap is on a distinguished road
Did you get any problems running the ballast inside the headlight unit? Are the slim-line balasts CAN-BUS compatible. Any problems at all with this setup? Thanks
Old 03-01-2010, 01:48 PM
geetee's Avatar
geetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant future
Very nice write-up. I initially had mine installed like this but changed the set-up a little. With everything inside the housing, there was too much heat. I had the lights on for 15 minutes in the parking lot, removed the ballast and all from inside the housing and it has literally burning hot. I'm not sure how much heat these can take. So what I did was relocate everything to the outside of the housing. I drilled a hole in the center of the housing back cover and relocated everything to the backside of the headlight housing and stuck the ballast onto the outside of it. So far its been fine.
Old 03-22-2010, 03:33 PM
Eck's Avatar
Eck
Eck is offline
Eck is on a distinguished road
Thanks for the info, another project for me to tackle.
Eck
Old 04-27-2010, 08:30 AM
KAZ911's Avatar
KAZ911 is on a distinguished road
great write up
Old 04-27-2010, 11:09 AM
KAZ911's Avatar
btw has anyone had any issues with the ballast being inside? (melting other wires. etc.)
Old 04-30-2010, 06:15 AM
EJ_2001_986_S's Avatar
EJ_2001_986_S is on a distinguished road
Did anyone ever do all 3 bulbs (High, Low, Fog)?
Quick Reply: 996 HID Conversion Kit - DIY
