6speed Technical Information forum This area is intended for members to post their technical questions that will be answered by anonymous experts posting as 411. Members may provide knowledge but sponsors are asked to not post in this forum.
996TT Tiptronic DIY leak fix advice needed
Old Mar 31, 2015 | 08:18 AM
914rrr's Avatar
914rrr has much to be proud of914rrr has much to be proud of914rrr has much to be proud of914rrr has much to be proud of914rrr has much to be proud of914rrr has much to be proud of914rrr has much to be proud of914rrr has much to be proud of914rrr has much to be proud of
Looks like I waited a bit too late to check out my tiptronic transmission mounts. Tranny is currently peeing on the garage floor. I've checked prior posts about this issue and all signs point to failed trans mounts (verified) causing the transfer case to flex, causing the transfer case gasket to be spit out. I found what looks like a small piece of the gasket on the plastic bottom cover.
I wanted to verify that part #'s 7 and 9 are the gaskets I need.
http://www.jimellisporscheparts.com/...ssembly=477479
I would rather get these from the local dealer, but they're quoting me 2-3 week lead time, and I need to get it back together before the PCA Bert Smith Poker Run on April 25th. Does anybody have a spare set they could "loan"me while I wait to get the dealer gaskets?
A friend tipped me off to some replacement polyurethane transmission mount inserts. Can anybody suggest a dealer (east coast or southern) closer to me to get these from?
http://cantrellmotorsport.com/produc...-trans-mounts/
Also, are there any "gotcha's" I should be aware of and is there anything else that would be a good idea to replace while it's apart?
BlackMarketRacing
Dec 8, 2015 01:49 PM
markski@markskituning
Aug 24, 2015 10:07 AM
00aston
Aug 24, 2015 09:29 AM
Fadi
Aug 21, 2015 03:43 AM
