6speed Technical Information forum This area is intended for members to post their technical questions that will be answered by anonymous experts posting as 411. Members may provide knowledge but sponsors are asked to not post in this forum.
2015 cayenne 958 sport suspension help
Old Oct 29, 2021 | 03:21 PM
heliace's Avatar
heliace is infamous around these parts
Angry 2015 cayenne 958 sport suspension help
HI All --
I'm stuck trying to install my new Bilstein B6 / H&R lowering spring suspension. I don't know how to compress the strut to attach the bottom bolt. I tried jacking up the strut but that resulted in the strut getting caught on the control arm. I reviewed the factory procedure ( 427117 ) but it does not address this issue. Please refer to the attached photo to see my issue exactly. Again, I tried to jack up the strut but it gets trapped in the control arm guide given the strut is larger in diameter than the mounting plates on the control arm .
Hopefully someone who has encountered this issue can comment --- TIA !
I need to compress the strut enough to put in the mounting bolt. FWIW -- the lowering springs are not engaged so no spring compression is necessary. These are Bilstein sport shock and are very tough to compress.
Old Jan 4, 2022 | 01:42 PM
figure1a's Avatar
figure1a is infamous around these parts
[QUOTE=heliace;4890767]HI All --
I don't know if I know the correct way but when I put Bilstein 5100s on my Tundra, I encountered the same issue. The only way I could get them in was to push the A-arm down with a hydraulic spreader. Maybe ask Bilstein if there is a trick/better way to it.
ciaka
Jun 14, 2018 09:14 PM
popsmuf
Cayenne 955/957
Mar 24, 2015 01:30 PM
Mz3bo
Cayenne 955/957
23
Aug 29, 2011 05:02 PM
kyeguy82
Cayenne 955/957
Mar 26, 2009 01:03 PM
GT3Racerich
Cayenne 955/957
Jan 13, 2007 09:31 AM
