Blew two rockers on my 930
Old Dec 2, 2009 | 08:50 PM
joed996's Avatar
joed996 is infamous around these parts
Hi All,
Two weeks ago I did a run with the er group and at about 100 miles into the run i heard a loud ticking noise from my motor. I thought i needed a valve adjustment. I brought it to my mechanic and he gave me the bad news. Appartly the ports that shoot oil into the rockers were clogged and two of my rockers blew out. This is the same mechanic who rebuild my motor, tranny, and turbo last year. He said their must of been some contaiments in your oil. I change the oil myself every 3,000 miles. Today i get the car back and its still ticking I asked my mechanic what is that tick he said i needs to break in then the ticking will stop. I'm lost has anyone else had this problem.
1984 930 turbo grey list, 4 speed, k27 turbo
Old Jan 10, 2010 | 06:42 PM
GG386's Avatar
GG386 is infamous around these parts
Not sure what "blew a rocker" means but when I had a chain tensioner give up the ghost it took out that side of the motor kissing the pistons on the way out. It wasn't a 930 motor, (pre-hydraulic tensioners), but the pain is just about the same.
Old Jan 10, 2010 | 07:11 PM
Arnie1's Avatar
Arnie1 has a spectacular aura aboutArnie1 has a spectacular aura about
There should be no ticking. Are the valves adjusted properly? Go to another mechanic!
Old Jan 22, 2010 | 04:52 PM
Devin1205's Avatar
Devin1205 is infamous around these parts
^2nd that. those motors don't tick unless something isn't set right. is it a injector type tick up top or a tick from below the motor?
Old Feb 5, 2010 | 12:39 PM
IAPorscheDoc's Avatar
IAPorscheDoc has a reputation beyond reputeIAPorscheDoc has a reputation beyond reputeIAPorscheDoc has a reputation beyond reputeIAPorscheDoc has a reputation beyond reputeIAPorscheDoc has a reputation beyond reputeIAPorscheDoc has a reputation beyond reputeIAPorscheDoc has a reputation beyond reputeIAPorscheDoc has a reputation beyond reputeIAPorscheDoc has a reputation beyond reputeIAPorscheDoc has a reputation beyond reputeIAPorscheDoc has a reputation beyond repute
Had a similar issue with 930 a few years ago. The cam towers take a beating where the cam rides when there is an oil starvation issue, and very well may need to be replaced on that side.
E55 Bulldog K2
Dec 15, 2015 08:38 PM
WheelsupZR1
Oct 20, 2015 08:36 PM
Jeff Kay
Sep 15, 2015 04:10 PM
Abuong01
930 Turbo
Sep 15, 2015 01:05 PM
