Max Boost TTS/TT question/test
Old Jan 23, 2015 | 09:52 AM
yllwturbo's Avatar
yllwturbo Is a GOD !yllwturbo Is a GOD !yllwturbo Is a GOD !yllwturbo Is a GOD !yllwturbo Is a GOD !yllwturbo Is a GOD !yllwturbo Is a GOD !yllwturbo Is a GOD !yllwturbo Is a GOD !yllwturbo Is a GOD !yllwturbo Is a GOD !
i have custom y pipe n intakes. maybe thats the reason im able to hold the boost all the way to redline?
Originally Posted by CPIGUY
What's the factory boost gauge reading when you get to 6000 rpm? I'm trying to determine if my car is malfunctioning. I'm being told that the factory gauge may be getting confused by the Stage 2 tunes modifications.
Will you be at the Shift3ector races on Saturday? I'd love to race you to see how our cars compare.
Old Dec 3, 2015 | 03:09 AM
TTSEssex's Avatar
TTSEssex is infamous around these parts
sorry to resurrect this old thread, but I have a few questions for all you knowledgeable guys around the world regarding the 991 TTS...
How do you know if the Overboost fuction is actually working? if you floor it in sport mode and hold it to near redline, then press the sport plus button, should you feel a surge and see the psi boost and torque gauges increase too??
similar to the OP, I rarely see any psi boost readings over 14/15psi regardless of whether im in sp or sp+. I don't seem to feel any differnet whatsoever when in sp+ mode. surely this can't be right?
has anyone else felt the same?
I know I'm long overdue a tune, but perhaps there is a functionality issue that I should get Porsche to fix before I slap on a piggy or flash...
even my kids think it feels slow now! WTF?!
any tests ideas I can do to check the 'S' part of my TT is working properly would be greatly appreciated...
thanks in anticipation.
Old Dec 3, 2015 | 06:55 AM
wrs's Avatar
wrs
wrs Is a GOD !wrs Is a GOD !wrs Is a GOD !wrs Is a GOD !wrs Is a GOD !wrs Is a GOD !wrs Is a GOD !wrs Is a GOD !wrs Is a GOD !wrs Is a GOD !wrs Is a GOD !
Here is a chart of a quarter mile run with MAP data
MAP is absolute pressure i.e. measured pressure in the manifold so to get boost you subtract 14.7. Course this is with a custom tune but boost hits 21-22 at the peaks. Probably look different without the tune but I haven't measured it that way.
Old Oct 20, 2016 | 05:13 PM
reisskhan's Avatar
reisskhan is infamous around these parts
Hi mate did you ever get to be bottom of this as we are experiencing same symptoms on a 991.1 tts
Car feels dead
Just about hits 1.0 bar/15 psi max 16 psi which is rare in sports plus
Can't really tell any difference in sports plus apart from the aggressive gearbox lol
Spoke to Sam and he's recommended doing a manual boost leak check but I can't seem to get my head around to making a boost leak tester so until that's done its bugging me
Also no warning or engine management light on etc
Obviously can go down the tune route but want to know if it's running normal as standard as to be honest it's been a bit disappointing with all the hype around these cars being super fast etc
Old Oct 25, 2016 | 11:12 AM
oebb's Avatar
oebb is infamous around these parts
I get this as well with a TTS I just bought. It reaches 1.1 (sometimes 1.2) for a brief time and then drops off to 0.9 or 1.0. I've tried to find a video on YouTube showing the boost gauge during acceleration but haven't found a good one yet.
Someone here must know if a stock car should be able to keep 1.2 bar/17 psi all the way to red line?
Old Oct 25, 2016 | 11:32 AM
CPIGUY's Avatar
CPIGUY has a reputation beyond reputeCPIGUY has a reputation beyond reputeCPIGUY has a reputation beyond reputeCPIGUY has a reputation beyond reputeCPIGUY has a reputation beyond reputeCPIGUY has a reputation beyond reputeCPIGUY has a reputation beyond reputeCPIGUY has a reputation beyond reputeCPIGUY has a reputation beyond reputeCPIGUY has a reputation beyond reputeCPIGUY has a reputation beyond repute
I've had this discussion on the forum back a year ago and the some guys swore that it pegs 17 psi all the way in every gear and other say it varies. My car hits 17 and drops off to 15 or 16 until shift and then back to 17 psi. What makes this even weirder is it sometimes stays at 17. Never understood why because I'm tuned and should be running over 17 psi consistently.
Old Oct 25, 2016 | 11:44 AM
reisskhan's Avatar
Only decent video I've been able to find showing the boost pressure gauge action is as follows
(From 1min30 onwards)
My car definitely doesn't do anything what that car is doing in the video
CPiGuy I think from my understanding the standard gauge only reads upto 17psi so to see the real boost pressure you'll have to hook up a software etc
Old Oct 25, 2016 | 11:49 AM
CPIGUY's Avatar
http://youtu.be/KWgNKSnP054
Yes, I'm aware that the gauge caps at 17 psi, which I would expect my car to hold through out the rpm range, but it doesn't and never has.
Old Oct 25, 2016 | 01:25 PM
gmd2003's Avatar
gmd2003 has a brilliant futuregmd2003 has a brilliant futuregmd2003 has a brilliant futuregmd2003 has a brilliant futuregmd2003 has a brilliant futuregmd2003 has a brilliant futuregmd2003 has a brilliant futuregmd2003 has a brilliant futuregmd2003 has a brilliant futuregmd2003 has a brilliant futuregmd2003 has a brilliant future
Depends on air conditions and temperature. These cars will reach their targets which often does not require the full boost the car is capable of.
Old Oct 25, 2016 | 01:31 PM
oebb's Avatar
So in a cooler environment the car will run with lower boost since it can achieve it's claimed power anyway?
Old Oct 25, 2016 | 01:34 PM
SamboTT@ByDesign's Avatar
It all depends on the tune and package. The stock turbochargers are small so turned up they do tend to taper off. We add hardware and tuning techniques to minimize this as much as possible until adding a turbo upgrade that can handle the flow.
Old Oct 25, 2016 | 01:39 PM
oebb's Avatar
My car is still 100% stock. I am planning on tuning it later but I want to make sure it's working as intended before any changes are made.
Old Oct 25, 2016 | 02:19 PM
I am sure it's fine if stock. A good test is to compare normal with sport+ so you can see and verify her touching 17
Old Oct 25, 2016 | 02:23 PM
reisskhan's Avatar
Oebb that's exactly what I am trying to do make sure it's running 100% on its stock form before modding it
At the moment car isn't exciting enough unless it's not running full power which I need to verify
Sam has suggested I do a boost leak check and another tuner said get a vbox and check the 100-200kmph to give an indication if it's running spot on or not
So looks like I've got some work to do lol
I don't mind as like doing the work meself and it's always a learning curve
COBB Tuning
Nov 3, 2015 08:39 AM
