Brake Boosting.
Old May 17, 2015 | 03:38 PM
UAE991's Avatar
UAE991 has a brilliant futureUAE991 has a brilliant futureUAE991 has a brilliant futureUAE991 has a brilliant futureUAE991 has a brilliant futureUAE991 has a brilliant futureUAE991 has a brilliant futureUAE991 has a brilliant futureUAE991 has a brilliant futureUAE991 has a brilliant futureUAE991 has a brilliant future
Brake Boosting.
Hello,
Couldn't find anything regarding that in the search.
It might be a silly question, but I'd like some input regarding this. Has anyone tried it? Results? Thoughts? Experiences?
Myself I have, and I found that if you brake boost properly, the boost seems to last at 1.2BAR longer. Whereas if you just floor it sometimes it doesnt even hit 1.2BAR.
Other times when you brake boost and pass a certain point the car jumps and lets go of the throttle itself(I believe)
Would like to see what you guys come up with, whether stock or modified. Although our turbos are small and there's minimal lag, but minimal is not zero and its notice-able, soo..
-Hamad
Old May 17, 2015 | 05:39 PM
991TurboS's Avatar
991TurboS is a glorious beacon of light991TurboS is a glorious beacon of light991TurboS is a glorious beacon of light991TurboS is a glorious beacon of light991TurboS is a glorious beacon of light991TurboS is a glorious beacon of light
Sorry to be ignorant here, but what is brake boosting?
Old May 17, 2015 | 06:54 PM
MurderedTurbo's Avatar
MurderedTurbo is a splendid one to beholdMurderedTurbo is a splendid one to beholdMurderedTurbo is a splendid one to beholdMurderedTurbo is a splendid one to beholdMurderedTurbo is a splendid one to beholdMurderedTurbo is a splendid one to beholdMurderedTurbo is a splendid one to beholdMurderedTurbo is a splendid one to behold
It's when you hold the brake and gas pedal down at the same time to maintain a speed and build boost while doing so. Only thing is I didn't think the factory ecu would allow this?!
Old May 17, 2015 | 06:56 PM
991TurboS's Avatar
OK thank you. Put the car into Sport+ and do that and you are in Launch Control.
Old May 17, 2015 | 07:24 PM
It's like a rolling launch. I didn't know these cars would do it without being tuned to do so. Mine is being tuned and having exhaust made for it right now or I'd mess with it. It's tough on the brakes over time.
Old May 18, 2015 | 09:50 AM
GT3 Chuck's Avatar
Administrator
Back on topic please
Old May 18, 2015 | 10:36 AM
Anyways so UAE991, you're saying you're able to brake boost on stock ecu in the 991?
Old May 18, 2015 | 01:34 PM
White991TT's Avatar
White991TT Is a GOD !White991TT Is a GOD !White991TT Is a GOD !White991TT Is a GOD !White991TT Is a GOD !White991TT Is a GOD !White991TT Is a GOD !White991TT Is a GOD !White991TT Is a GOD !White991TT Is a GOD !White991TT Is a GOD !
I would love to figure this out as well. Assumed blow off valves would open and purge boost at part throttle?
Old May 18, 2015 | 06:51 PM
UAE991's Avatar
Thank you Chuck,
Regarding the topic, couple weeks back I opened a thread asking about maximum boost you get in a stock turbo. People said 1.2 initially on lower RPMs and then it drops to 1.0
Which is what I was getting aswell in a Turbo S, brake boosting however.. trying it made me notice getting 1.2bar of boost on higher RPMs and for longer.
However the computer stops you when you've held the boost for too long or you've braked too hard one or the other, but at some point it gives up and says no. but it's definitely do-able and you can, for a fact, brake boost in a stock turbo. What i decided to do(from experience so far) is brake boost til 0.5 or 0.7 and then go.
Would love to see some of you guys try and see what you come up with.
-Hamad
Old May 19, 2015 | 08:43 AM
wrs's Avatar
wrs
wrs Is a GOD !wrs Is a GOD !wrs Is a GOD !wrs Is a GOD !wrs Is a GOD !wrs Is a GOD !wrs Is a GOD !wrs Is a GOD !wrs Is a GOD !wrs Is a GOD !wrs Is a GOD !
Originally Posted by UAE991
Thank you Chuck,
-Hamad
Is this better than launch control? I admit to being somewhat confused. I guess if you aren't in sport maybe its one way to get going without going to sport plus?
Old May 19, 2015 | 08:52 AM
Porsche Boy's Avatar
Porsche Boy is a jewel in the roughPorsche Boy is a jewel in the roughPorsche Boy is a jewel in the rough
To my understanding brake boosting is applied from a roll on. Say you are going at 50km. Someone pulls next to you and you try to find a fine line between braking and accelerating at the same time. So basically you are getting some boost staying at the same speed at 50. Once you let go, you get a stronger pull from that certain speed because of the boost being generated.
Think of it this way. You go at 50km being in gear 2. You are around 4 - 4.5k.
If you do not accelerate you will see there is no boost building up. (Psi or bar). With brake boosting you will get some psi going before you let go.
Hope that helps.
Old May 19, 2015 | 09:15 AM
wrs's Avatar
wrs
Hope that helps.
Oh, OK, wow, that seems to me like it would be hard on the brakes. I get the reasoning though, especially if you are just driving around in sport and get challenged to a roll race. Otherwise I would say that if you can get to sport+, the computer will pick the right gear and get to it pretty quickly I think. There was a feature on the M5 that if you pushed the pedal all the way down to where it clicked, it would downshift to the best power gear for the speed you were going and increase boost at the same time.
ModBargains
McLaren Vendor Classifieds
Oct 13, 2015 03:41 PM
ModBargains
Oct 13, 2015 03:40 PM
ECS Tuning - VW
Sep 2, 2015 09:03 AM
