My Top 5 991 TT/S Bolt On Mods
Originally Posted by changster
Sorry I'm just trollin'. I have AMS IC's and it hasn't made me faster either.
What I do know is that there were significant gains on the Dino from going from GX stage to the GIAC stage 2+ with intercoolers and that I pulled on cars at the driving force club runway event once I had to set up that I did not pull on before.
The one change I definitely did notice in dramatic fashion was in heat soak. When I just had the GIAC stage 2 with stock ICs I would only get one fast run and then the ECU would cut the power dramatically on subsequent runs which I discussed in prior threats. The GIAC stage 2, as stated by the tuner, really and forcefully shuts down power once IATs start to rise due to the stock intercooling which is not adequate for that level of tune. With the stage 2+ and upgraded ICs, not only do they turn up the power but it becomes repeatable without the big power cut on subsequent runs after the first one.
Originally Posted by E-Gear
BTW, my friend, just because someone else ran a certain time with similar set up as yours, it does not mean that you would run the same. Many variables are at play, such as driving skills, weight and so on. The only way to be 100% sure that you can run 10.1's or better is to go out and do so yourself. Otherwise, all you doing is speculating. I'm just sayin'Bigger IC's don't usually add more ponies. However, they do help keep IAT's down when the boost is turned up and/or when out making repeated runs.
Thanks,
E-Gear
Thanks,
E-Gear
krikra
Mar 7, 2016 06:48 AM
Wealth Manager
Feb 24, 2016 02:49 PM
